kinda hard to explain plz help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
This is a discussion on kinda hard to explain plz help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by mycologist Oh wait, it sounds most like your clutch is slipping now that I read the quote. ...
    Registered User s202rxi's Avatar
    May 2008
    Buffalo
    Oh wait, it sounds most like your clutch is slipping now that I read the quote. Your RPM's jump? If so bad clutch. I was distracted by the boost which is just following the load when it slips.
    That could be very possible that it is your clutch, im changing out all my spark plugs because i also have a rough idle. Im going to regap them at the smallest subaru recomends and see if that does the trick for me. If not im doing the clutch aswell.
    Blobeye Syndicate # 111
    2005 WRX OBP 5MT.....Invidia cb, Helix dp, Cobb Ap stg. 2, Intake silencer delete
    Registered User simplyyestb's Avatar
    Mar 2009
    oklahoma
    Quote Originally Posted by s202rxi View Post
    I think i know what your talking about because im kinda have the same issue. Its like a back and forth movement when you realy give it gas?
    YES that is exactly what it feels like!!
    Mar 2009
    oklahoma
    let me know how that works out for you!
    i just might have to change mine out
    sure would be cheaper then new clutch
  6. #19
    May 2008
    Buffalo
    Quote Originally Posted by simplyyestb View Post
    ok ill let you know i pretty shure ill be doing it this weekend.
  7. #20
    Mar 2009
    oklahoma
    here are some pics
    let me know if you want more or different ones
  8. #21
    Mar 2009
    oklahoma
    so a couple of my friends are saying its a problem with my waste gate not opening so I'm over boosting and getting a fuel cut... what do you guys think about that?
  9. #22
    Registered User 19josh97's Avatar
    Mar 2009
    Stock wastegate could be going out... RPMs dont slip... you floor it boost goes full then drops 5-8 psi, shoots right back up and goes down 5-8, just hitting full, dropping, back and forth back and forth? Yes?
  10. #23
    Registered User Truckster27's Avatar
    Mar 2006
    Everywhere
    Sounds like your having a problem with the boost solenoid. Its not able to respond quick enough, essentially you overboost, then the solenoid kicks in and begins to open the waste gate, but opens it too far and fast, so it closes and begins to build boost up again and then overshoots, and continues to modulate. See this a lot in cars that go to stage 2 (remove the catted up pipe and either remove the exhaust cats or replace with a hi-flow cat) without a tune. In extreme situations, you overboost so far that you hit feul cut, and trust me, you'll know if that happens! Either the previous owner removed and reinstalled the vaccum lines incorrectly, or the boost solenoid is not working correct, or a combination of the two. Or your exhaust has been modified like above. Really does sound like "boost hunting" to me...
    Movn' on up to an '06 WRX
    Vf-39 all the way!
    Love to build 'em, just to ship 'em out and start all over!
    I got friends in cyberspace, so I must be cool, right?
    Facebook / Myspace
  11. #24
    Mar 2006
    Everywhere
    Well, your friends proably aren't right in the feul cut, but close to the problem. When fuel cut occurs on a WRX, it'll feel like you straight hit a wall, its that jarring. Plus, your Check Engine Light will come on, and your Cruise control light will flash. That, my friend, is fuel cut. Do that more then a few times, you won't have to worry about diagnosis, you'll have a lawn ornimate!
    Vf-39 all the way!
    Facebook / Myspace
  12. #25
    Mar 2009
    oklahoma
    thanks for all the help guys I'm i think ill just take it up to the nearest Subaru dealership when i go to court in 10 days
    (by nearest i mean an hour or more away)
    ill let you know how it goes
    if anyone else has anything to add or anything i should ask them let me know
    ill just be crossing my fingers that it wont cost me to much because
    that + traffic ticket + paying off my car > broke
    so wish me luck!
  13. #26
    Mar 2009
    oklahoma
    Quote Originally Posted by 19josh97 View Post
    Yeah pretty much
    well i don't have a psi boost gauge i have the other type that is confusing to read;
    but yeah its kinda like I'm bouncing of a red line i guess and i see both my boost gauge and my rpm bounce a bit
    and depending on if its doing this in first or second it hits hard
    first = hard
    second = soft
  14. #27
    Mar 2009
    oklahoma
    fixed
    so i finally made it to the stealership they replaced my air/fuel ratio sensor my MAF sensor and my fuel pump they charged me like 550 i was probably ripped off but screw it i didnt know what was wrong
    on the plus side my buru pulls SO MUCH HARDER
    im in love all over again
  15. #28
    Oct 2005
    Late Devonian
    GOod to hear. Yeah, you can't complain about the $ if they fix it.
