Loud Tick Noise
Results 1 to 5 of 5
This is a discussion on Loud Tick Noise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi guys, I'm getting a strange loud ticking sound, sort of like two metal plates colliding or banging each other. ...
    nfm
    nfm is offline
    Feb 2008
    Orland Park, IL
    Question Loud Tick Noise
    Hi guys,
    I'm getting a strange loud ticking sound, sort of like two metal plates colliding or banging each other. It happens when the car starts moving when I gently let out the clutch while in reverse, taking foot off the gas while in 2nd gear, and shifting from 2nd to 3rd gently with little of gas. What I hear is a single tick as if something was loose. It's pretty annoying and embarrassing, any ideas? Stock 2005 WRX, 30K miles.
    2005 WRX
    - TD04 19psi, GM EBCS, TGV Delete / Perrin Crank Pulley
    - APS 65mm CAI
    - Catless Invidia UP/Helix DP, A'PEXi N1 Catback
    - Kartboy Shifter Bushing/Perrin Rear Diff\Outrigger Bushings
    - Group N Engine/Pitch Stopper/Trans Mounts
    - 2005 STI Springs
    Aug 2008
    Kennett Square, Pennsylvania
    check that all of your exhaust heat shields are properly secured...
    nfm
    nfm is offline
    Feb 2008
    Orland Park, IL
    Thanks for the reply, everything looks secured under the car, I'm pretty sure that the sound comes from front diff or close to it . I have replaced rear diff fluid today. I should be getting Redline Shockproof gear oil soon so we will see if that going to help my transmission/front diff. Here's a long thread with similar issues Rear diff clunk / knock - IWSTI.com: Subaru WRX STI Forums
    2005 WRX
    - APS 65mm CAI
    - 2005 STI Springs
    Oct 2005
    Late Devonian
    Quote Originally Posted by nfm View Post
    I didn't read the whole thread. It is really long.
    I recommend rear diff bushings and transmission bushings. It's not perfect but definately better.
    nfm
    nfm is offline
    Feb 2008
    Orland Park, IL
    Found The Cause
    Hi guys,
    I finally found out what's making the noise, looks like it's a broken tie-rod and the boot above it where I found grease all over the place, here's a video:
    YouTube - 2005 WRX Tick Sound
    It's very loud. When driving the car it sounds like the sound is coming out of the center diff, that got me scared. Easy way to test it is to put your car in gear and try to rock it back and forth. Now I need to find a cheap replacement part, any pointers?
    2005 WRX
    - APS 65mm CAI
    - 2005 STI Springs
