Could be a lot of things, it just points out that you have plenty of blow-by. How much oil is in your intercooler?
This is a discussion on AAHH! Oil out the BOV!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok, so I checked my oil when I gassed up at lunch and theres a little bit of oil on ...
Ok, so I checked my oil when I gassed up at lunch and theres a little bit of oil on my BOV. it is aftermarket. Not a lot but enough that I can see it, looks like its coming out of the blow off. There's no excess spray anywhere else, just in the 'cone' of the blowoff valve.... Bad seal? Bad Turbo? I don't know what to do?![]()
haven't had the opportunity to check yet, I just seen it on my lunch....
how do you check if there is oil in the innercooler
Check to see that the PCV is working. That's the cheapest potential problem.
