94 wrx oil shoots out from dipstick
Results 1 to 4 of 4
This is a discussion on 94 wrx oil shoots out from dipstick within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi first of all my subaru has started to misfire at low revs it used to misfir throug any revs ...
    Mar 2009
    hi first of all my subaru has started to misfire at low revs it used to misfir throug any revs but i cleaned up plugs and it only does it at low revs now and doesnt idle properly, it ok from about 2k revs and above
    next the major problem it shoots out oil from the dipstick tube and i even had a small fire from the oil burning on the exhaust.
    everytime i put the dipstick in and take it for a drive up the the road it will shoot up and theres oil everywhere.
    please help!!
    Make sure the PCV system isn't clogged. It sounds like the crankcase is being pressurized. This could be a clogged vent system or it could be a problem with the piston rings. If the PCV system checks out OK take the car to a shop and have them see what state the motor is in.
    Mar 2009
    where is the pcv on the engine and if the pcv is ok would a compression test tell me what state the piston rings are in.
    what figures should i be looking for
    My motor is a later model than yours and for another market so likely they will differ. Try scoobynet.co.uk for specs.
