Mass Air Flow Sensor
Results 1 to 7 of 7
This is a discussion on Mass Air Flow Sensor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a 2002 wrx, engine management light has came on and lost all its power, its been into the ...
    Feb 2009
    i have a 2002 wrx, engine management light has came on and lost all its power, its been into the garage they said it has a number of different faults showing, they said the first port of call is the mass air flow sensor but it could be the butterflies that sit before the injectors aparently, any one got any ideas can the mass air flow sensor be tested/repeared?
    Cheapest option is to clean the MAF well with an appropriate cleaner, then check for vacuum and boost leaks, check for intake leaks, and go from there.
    Feb 2009
    ok cheers whats the best cleaner electrical cleaner or carb cleaner something along those lines?
    It's essentially an electronic part. I'd use electric cleaner and avoid carb cleaner, as the solvents used may not be appropriate. If you are in the US, many auto parts stores sell a product designed specifically to clean MAF sensors that leaves no residue and does not contain harsh solvents.
    Make sure the air filter is clean, the intake is clean, and that the filter housing is seated correctly too. See here assuming the error code is PO171, but also to get ideas in general:
    P0171 CEL Thread - Everything you ever wanted to know? - NASIOC
    also:
    MAF Sensor Maintenance By iMR2
    since the sensor our cars use is very similar to the one shown.
    Be careful with the MAF, it is more a piece of electronics than an auto part and is delicate.
    Aug 2008
    Kennett Square, Pennsylvania
    Another good test for the MAF sensor is ...With the engine running...take like the butt end of a screwdriver and tap on the sensor housing...if the car stumbles/ runs rough/stalls...you've found your problem...
    Dec 2003
    Dallas, TX / Sterling, VA
    If you need a new one I'm selling one
    Moderator Donkey's Avatar
    Da boonies,Va
    CRC makes a MAF sensor specific cleaner.You need to find out what exactly the codes are.Could be just the test connectors are together.
    2002 FORESTER S
    1998 FORESTER S
