Engine Knock
Results 1 to 6 of 6
This is a discussion on Engine Knock within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I need a second opinion on a motor knock. I ran my car at the track and it ran great. ...
    Sep 2004
    Engine Knock
    I need a second opinion on a motor knock. I ran my car at the track and it ran great. On my way home my check engine light went on so i pulled over and checked it out. Was pulling a bank 1 is running to lean so i got it home and turned it off. In the morning I turned it over and a horrible knock came from the motor. It sounded like I threw a rod bearing. Not sure though, any input?
    EJ20 with fp green, 800cc injectors, protuned, FMIC, Arp head studs, Crower valve train, light weight pully, flywheel, new timing belt.
    Oct 2005
    Ocean Grove, NJ
    that's a bit much for the stock internals
    what are your afr's like?
    dyno sheet?
    Sep 2004
    afr's if can remember are 14-20 idle, not sure reved, 298 wheel at 16 lbs when i ran it, was tuned at 348 at 21psi as well, but was running the 298 at the time
    Dec 2003
    Dallas, TX / Sterling, VA
    Green is too big for stock internals. Can you be more specific on the sound?
    How high are you reving with that valvetrain?
    Sep 2004
    just a very loud lock coming fro the engine, 7.1k rpm
    Oct 2005
    Late Devonian
    Without a recording it is difficult to get an idea what it might be. You might have a look at the timing belt and make sure it didn't jump some teeth. I'd say you are most likely looking at pulling your motor out though. It is crucual that you figure out why it happened or your next motor may be toasted too.
