Ticking Noise after Timing Belt Change: VID
Results 1 to 5 of 5
This is a discussion on Ticking Noise after Timing Belt Change: VID within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2002 WRX I just replaced: 1. Timing Belt 2. Cam Belt Tensioner 3. Pullies 4. Waterpump 5. Thermostat Started it ...
    Oct 2008
    2002 WRX
    I just replaced:
    1. Timing Belt
    3. Pullies
    4. Waterpump
    5. Thermostat
    Started it up and started hearing this ticking noise that is constant with my rpm's. It doesn't go away when the car warms up. Here's a video
    YouTube - 02 WRX Ticking Noise
    Any suggestions?
    Aug 2008
    Kennett Square, Pennsylvania
    Well if the noise wasnt there before you did all the work than i would def. go back and double check everything is tight....are you absolutely positive the timing marks are dead on? I have seen a few techs put timing belts back on DOHC H4's...start her up...clack clack clack clack clack....only to find out they were off a a couple teeth....Personally I would go back and double check t-marks and everything....by the way how many miles are on the car?
    Oct 2005
    Late Devonian
    Yeah, you need to go back in. It sounds like it might be the tensioner. Let us know how it goes.
    Oct 2008
    I replaced my belt tensioner with a brand new one...would it be ok to use a c-clamp to push the tensioner down?? or does this destroy the seal in it?
    Registered User T.J.'s Avatar
    Oct 2002
    on a boat...
    Quote Originally Posted by mrbigshot View Post
    It should be ok. Just do it slowly. I believe they say that it should take 2 min. to compress it fully. I have done it w/o trouble.
    Good luck, T.J.
    200,000 mile club.
    Old Irish adage: "Do not resent growing old. Many are denied the privilege."
