pcv valve hose question
Results 1 to 6 of 6
This is a discussion on pcv valve hose question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my question is, is this the pcv valve hose(where i convienently marked an arrow pointing to it in blue with ...
    Registered User JoeMomma's Avatar
    Apr 2008
    Monmouth County, NJ
    my question is, is this the pcv valve hose(where i convienently marked an arrow pointing to it in blue with "here" written under it lol)? cause i just got some sea foam and i know youre supposed to put it through the pcv valve but i dont where it is on this car as im still fairly new to it so can some one tell me if this is it or not? lol
    bugeye maffia member #304 l http://www.flickr.com/photos/joe_fonseca/
    Aug 2008
    Kennett Square, Pennsylvania
    No thats not the PCV valve....you can actually pop the seafoam in at any manifold vacuum source...personally i try and put it close to like the plenum so its not just going into one cylinder (ex..like i wouldnt put it on the vacuum line that goes to the power booster because thats only pretty much getting to cyl #4...ok see the little vacuum hose to the left of the red. alt. electrical connector..between that and the throttle and cruise cables...personally what i have done for every Subaru with this setup i pop that line off have it siphen right thorough there....im not to sure what kind of "kit" you have to get the seafoam in there though....
    Registered User Pactin's Avatar
    Nov 2007
    California
    PCV valve should be under the throttle body on intake manifold.
    --Justin
    Hawk-Eye Alliance #128
    Apr 2008
    Monmouth County, NJ
    ok so do i take it off from the top of that hose which is right next to the red electrical connector, or at the bottom of that hose?
    so its this one(this time i marked it in red and wrote "this one?" under it lol)
    Aug 2008
    yes...just pull the hose off from the intake manifold dont try and trace it down and pull it off whatever sensor it goes too...ive actually broken like the EVAP purge solenoid on other subaru's trying to do that..lol...anyways the one you wrote "this one?" on..yes that is the line im referring too...as i said im not to sure what kind of kit you have to introduce that stuff into the manifold with...
    Apr 2008
    Monmouth County, NJ
    okay never mind i did it from one of the vacuum lines of the bpv, but thanks anyway
