so much problems, please help!
Results 1 to 15 of 18
This is a discussion on so much problems, please help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i got this comment from my friend.. "u NEED to get ur car looked at. the previous owner of that ...
    Registered User gygibigi's Avatar
    Dec 2008
    "u NEED to get ur car looked at. the previous owner of that car and he said he drove that car HARD. it was repo'd and he replaced the aftermarket turbo with the stock one. thas y theres a BOV still there. He also ran it at 120 from LA the WHOLE TIME. the ecu is still programmed to work with the aftermarket turbo which u DONT have.doode get ur car looked at. he says theres about only 7k miles left in the transmission and the internals are like effed.just lettin u noe."
    what should i do and how much will it cost me?
    Quote Originally Posted by gygibigi View Post
    Where is LA? Where did he run it from, and where to? How long was "the WHOLE TIME?"
    Is there a way of making sure there aren't, say, 6K or 8K left on the transmission?
    The internals to what? The transmission? What does "effed" actually mean? Who takes the time and has the knowledge to correctly spell "transmission" but can't manage "letting," "you," or "know?"
    what should i do
    Contact your friend and advise them about the spelling problems. Take your car to a Subaru specialist if you are having problems -- but be more specific about what those problems might be than your friend has been.
    Your cell phone plan may already include free texting. If not, prices tend to run about $0.10 per message, but check with your carrier.
    As for the car, I can't say. Nobody can, because there is no information about the problem(s) you're having.
    - Al Stewart
    Dec 2003
    Dallas, TX / Sterling, VA
    Based on what you said (or rather the lack of what was said), the ONLY things we can answer are:
    -Yes, you need to get the car retuned (stay out of boost)
    -Yes, you friend is extremely illiterate and probably dropped out of school in the 1st grade.
    Quote Originally Posted by brfatal View Post
    Notice though how well the friend did on "programmed," "replaced" and "aftermarket," not to mention "transmission," only to dish out "doode," "ur," "thas y," and "theres." It's quite something.
    - Al Stewart
    Dec 2008
    ya my friend is dumb. im coming from the bay area.
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    look just stop. Slow down. Is the engine idling correctly without noise. Is your oil looking clear? Do a engine oil change. Listen for ticking, knocking, etc. once it warms up. Now drive and shift thru the gears. Are they smooth? Is the clutch slipping? Are the gears not working (ie, no 2nd gear).
    Quit listening to others and pay attention to what your car is telling you. If it's screwed you will know...
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Dec 2008
    what oil do you guys suggest?
    Dec 2006
    Philly/DE area
    5W-30, any brand. You can use Synthetic too (like Mobil One 5W-30)
    The real question is how is your car running now?
    What oil does Subaru suggest? They'd know best. In general look for something with an API symbol on it, in 5W-30 weight, and start from there. This forum has a dedicated "oil change" thread that has thousands of posts with info, but at the end of the day, all that matters are manufacturer specifications for each motor and oil analysis data. Both are available in that thread, but the maker specs are also in your user's manual.
    BTW, having driven from Los Angeles to the Bay repeatedly, I find it amazing that anyone could maintain 120 mph. At times, even 120 kph is questionable. There's lots more people using the same two roads nowadays. Find out what facts are available about the car, and if there's a problem either post specifics or have a mechanic look at it.
    - Al Stewart
    Dec 2008
    i didn't hear any ticking or knocking. and the gears and clutch seem to work fine.
    is there a way to help prevent my transmission from being "effed"?
    Your author friend would be the best person to ask that, since they know best what exactly they meant by that.
    There's also a long thread in the transmission forum with details about different gear oils and the experiences people have had with them, plus there are threads on transmission problems etc.
    - Al Stewart
    Dec 2003
    Quote Originally Posted by Pavia View Post
    You just recommended one of the worst oils he could choose.
    Dec 2008
    would it be cheaper/better if i were to get it retuned or get a new turbo in the future?
    Registered User indytruckboy's Avatar
    Oct 2008
    Reading, PA
    retuned
    I work on vehicles that make 650hp and 2400ft/lbs.
    Registered User twitchit's Avatar
    Apr 2008
    Raleigh NC
    Are you mechanically inclined?
    Is there a check engine light?
    How deep are your pockets?
    If you answered yes to question 1 then start searching, everything you need to know is probably on this site.
    If you answered yes to question 2 then get it scanned and see what codes it's throwing. If you answered yes to question 1 then get to work. If you answered no to question 1 then take it to a garage familiar with subaru's or a dealership with a good rep.
    If you answered deep then you picked a good car because if it was beat on it's gonna cost you(but it is somewhat rewarding).
    If you answered shallow then you might be "effed".
    Who knows your car might be fine; then again it might not. I'd get moving on that and at least get it checked out.
    Welcome and best of luck!
    05 STI....someday
    04 WRX cobb stage 2-sold
    00 Civic Si-sold
    95 240SX-sold
    02 F-350 7.3L Powerstroke Diesel
