whats wrong with my car!
Results 1 to 9 of 9
This is a discussion on whats wrong with my car! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; traded in a 05 lgt wagon for a 06 wrx limited with 29k 4 hours after i bought the thing ...
    Dec 2008
    berkshire MA
    4 hours after i bought the thing it started humming
    humming got much louder sounded like a can in a bike wheel
    when i slowed down to a stop it clicked wicked loud.
    dropped it off to the dealership with 30 miles on it
    3 weeks later (yesterday) i get it back
    picked up gf to go shopping and it started humming again
    it started getting really loud it soulded like a truck in 4w low as if the transfer case was screwed up.
    then when i pulled out of an intersection and it popped out of gear and made a loud vibrating grinding noise i was probably going 15 mph
    as i caosted down a hill i had the clutch pused in and it kept jumping in and out of that humming noise as if it were catching a gear
    dropped it off at the dealer with 24 miles on it
    what the hell is wrong with this car i paid 18G for?!
    help me soo i can tell the dealer (haddad) because obviously they cant fix ****!
    Registered User NjBuGeyEdWRX's Avatar
    Apr 2007
    Beachwood NJ
    what did they come up with the first time?
    sounds like a tranny problem though.
    how many miles where are the car when you got it/ were there any mods done to the car before that?
    is the dealership your bringing it to a subaru delaership or not? if not bring it to a subaru delaership or subaru specialist.
    03 WRB WRX STAGE II
    STi COMING SOON
    BUGEYE MAFIA #199
    LET ME QUOTE THE LATE COLONEL SANDERS " I'M TO DRUNK TO TASTE THIS CHICKEN . . ."
    Dec 2008
    berkshire MA
    no mods
    its got 30,128 miles
    noted
    ROAD TEST WITH CUSTOMER VERIFIED CONCERN. SET UP ON LIFT AND LISTENED FOR NOISE. FOUND NOISE IN TWO DIFFERENT PLACES, COMING FROM INSIDE THE TRANSMISSION AND THE CENTER DIFFERENTIAL.
    list of things replaced first time:
    center diff ay
    ball bearing
    2 different roller bearings
    gasket
    gasket muffler
    cylindrical roller bearing
    thrust bearing
    needle bearing
    2 oil seals
    an o ring
    noted:
    REMOVED AND DISASSEMBLED TRANSMISSION AND DIFFERENTIAL. FOUND PITTED RACES AND SHAFT BEARING IN DIFF. REPLACED RACES AND BEARINGS. FOUND PINION BEARING AND OUTPUT SHAFT BEARING IN TRANSMISSION
    This is Haddad subaru of Pittsfield, its a subaru dealership.
    They also charged me 56$ for the removal of my anti theft lug nut because they couldn't find the soket to fit it?
    I JUST BOUGHT THIS CAR! IVE ONLY DRIVEN MAYBE 45 MILES AND BOTH TIMES IT BROKE
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Get a new tranny. My guess is the "pitted" bits had metal floating through the gear box causing damage. Demand a new tranny.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Apr 2007
    Beachwood NJ
    Quote Originally Posted by 06wrx4me View Post
    +1
    56$ for removing a lugnut?
    03 WRB WRX STAGE II
    STi COMING SOON
    BUGEYE MAFIA #199
    Dec 2008
    berkshire MA
    for 4 anti thieft lugs. but they charged me? its there fault i couldnt get it off cuz they lost it!
    its not only the tranny. they said something about the viscus coupling. Also when i got it back the shifter had alot of play in it like id put it in 1st and i could jiggle it as if it were in neutral. it was like this in all 5 gears
    They blamed it on me cuz im 6' they said i might of ridden the clutch. All my cars before this were stick
    Registered User Bedhead42's Avatar
    Jan 2008
    Denver
    Take it to a different dealer, they are yanking your chain for sure!!!
    Jun 2006
    Nor Cal
    Quote Originally Posted by lttleredwagon View Post
    They tranny and center diff are expensive, they are trying to get you to admit wrong doing do they don't have to cover it. Politely talk to the service manager and explain whats going on. If he is not receptive, speak with the general manager. If he is not receptive, speak with the owner. Let them know you bought a used car from them and 100 miles later the tranny blew up still under waranty and they are trying to blame you instead of the previous owner. Usually thats as far as you need to go to get the service you need.
    Word of advise.
    1. Don't get indignant...act professional.
    2. Don't threaten litigation, that makes every door shut immediately.
    3. Calmly reinforce that you did nothing wrong, you aren't a "hot rodder" and the vehicle regardless of blame is still under factory warranty on the drivetrain until 60,000 miles.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Dec 2008
    berkshire MA
    the dealer has a 30 day warrenty under it soo they legally have to fix it.
    there *******s my dads a ase master mechanic he told them whats wrong and they keep holding it off saying they will look into it. its just gunna be another 2 weeks then it will just break again in like 20 miles
    i got a hold of subaru of America there gonna get a hold of this dealer. i would take it to another dealer but the closest one is 35 miles away ( little over a hour ). My car cant even make it outta my town. its back at the dealers anyways
    they suck they got three shots to fix my car.
    there using there second....
