Burning Smell from engine
Results 1 to 15 of 15
This is a discussion on Burning Smell from engine within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, I have an 05 WRX. I recently started smelling burning rubber coming from the engine. I can only smell ...
    Registered User kosmo's Avatar
    Dec 2008
    Vacaville, Ca
    Hello,
    I have an 05 WRX. I recently started smelling burning rubber coming from the engine. I can only smell it when I am stopped it seams. I opened the hood to find a light smoke coming from around the air filter or under along with the smell. Please help
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Quote Originally Posted by kosmo View Post
    Hello,
    Maybe a hose is burning..... Take a pic of the spot..... We won't be able to tell without something else....ie... what you have done to the car recently, modifications.
    If you know where the smoke is coming from, you should be able to pinpoint it.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Dec 2008
    Vacaville, Ca
    The only thing I did was get the oil changed.
    Power steering leak, power steering belt slipping, or coolant leak.
    Jul 2008
    San Antonio
    look where the smoke is coming from.... Have seen when they fill the car up w/oil, they get it everywhere..... could be that. Get under the car and search around.... chk yur dipstick
    N-swinger
    2000 Escort
    Dec 2008
    Vacaville, Ca
    I was checking it out more on my lunch break. Those bastards didnt put the air filter cover all the way back on. I dont think this is the cause but nevertheless.
    Jul 2008
    San Antonio
    Another reason to do all (90%) of your maintenence yourself.
    N-swinger
    2000 Escort
    Aug 2008
    Kennett Square, Pennsylvania
    check your axle boots..not known to cause that much smoke but they can cause a hell of a burning smell if there torn..throwing grease all over the cat. conv. or downpipe....
    Dec 2008
    Vacaville, Ca
    After driving home that night the smell was still there, no smoke though. It's been raining and very cold here so it's hard to tell if it's smoke or rain drops falling on the engine while the hood is up. The next day I drove to work again and the smell seemed to not be as strong. I'm starting to think it was the morons at Jiffy Lube splashing crap all over the place and it was burning off.
    I would rather be safe than sorry though.
    Side note, my check engine light at night seems to be on but so dim almost seems off. I'm not sure what this means. Anyone had this issue as well?
    Aug 2008
    we've had this a few times...the oil filters on these things are in a really awkward place..right between the headers/manifold whatever you want to call it....personally ive made it a note to spray the whole area of the exahaust off with brakekleen..that usually takes care of it.....
    As for you CEL..double check that you have no codes in the system...than a shot in the dark i would say you have a loose wire somewhere....
    Registered User Ditch64's Avatar
    Apr 2007
    Detroit
    if you just put a TBE on then its probably your A/C drip hose, right next to the Downpipe. mine did it and i just kinda ziptied it to something i dont remember. but ya jiffylube likes to suck at everything so it may have been them lol
    07 WRX CGM, blouch tdo6 18g and supporting mods. Defi racer series gauges, some other random stuff.
    04 Nissan Titan 4x4 LE CC Silver (Sold and missed)
    HAWK EYED ALLIANCE #686
    Registered User msedillo's Avatar
    Sep 2008
    New Mexico
    Dont take your car there man they arent worthy to change subies blood. I had a buddy take his car over there to change the diff oil and never put the plug back on. just imagine what that did...it wasnt pretty.
    God created turbo lag to give V-8's a chance
    Registered User twitchit's Avatar
    Apr 2008
    Raleigh NC
    I used to work at a valvoline instant oil change so i know sloppy work when i even hear about it. The subie's headers kinda loop around the oil filter on some models. Getting oil on the headers or heat shield at least is pretty unavoidable when trying to get the job done fast. You throw on a speed bar and crush cup and just spin that filter off and oil just goes everywhere. It's just the oil burning off and should be gone pretty soon. You might want to check to make sure there's not any oil leaking from around the filter though. Jiffylube has a tendency to not prime their filters.
    05 STI....someday
    04 WRX cobb stage 2-sold
    00 Civic Si-sold
    95 240SX-sold
    02 F-350 7.3L Powerstroke Diesel
    Dec 2008
    Vacaville, Ca
    A few drives later the smell seems to be going away. It has gone to the point where I can't even directly pin point where it's coming from. Since I can't change my own oil in my apartment complex I have to take it where and when I get a chance. I will not be going back to hack lube any time soon.
    Aug 2008
    try and find a Subie dealer to bring it to if you cant do it your self because of the apartment dealeo....the dealer were i work charges i believe under $30 for an L.O.F....
