car keeps poppin a MIL
Results 1 to 5 of 5
This is a discussion on car keeps poppin a MIL within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; well here is the problem i have a 03 WRX it runns fine for about a hour then it cuts ...
    Registered User jessie_james_06's Avatar
    Dec 2008
    houston texas
    well here is the problem i have a 03 WRX it runns fine for about a hour then it cuts off and popps a MIL i read the code and it says that high exhaust temp was detected i wrok at a performance shop but it is for nissans only so my bosses or any of the other techs dont know alot about subarus i think it may be a o2 sensor and it is causeing the car to run lean wich would make the cylinder heads hot along with the exhaust but a o2 sensor is almost 200 bucks so i would like some other opinions to see what other ideas people might have
    25 psi and loving it
    Dec 2008
    What code # p0?? ?
    converter failure is common on subs as is a/f sensors failure.
    Dec 2008
    houston texas
    i cant remember the code but it is sayong high exhaust gas temp
  5. #4
    May 2005
    Phillytown, PA
    You probably need to replace the EGT probe that is in the uppipe. They're about $40.
    Are you running a catless uppipe? If so, you should consider some getting some Engine Management and deleting that CEL code.
  6. #5
    Registered User indytruckboy's Avatar
    Oct 2008
    Reading, PA
    That code could be a couple of things. The one to worry about is a clogged up cat. If the CEL flashes at you, that's when you stop driving. That means "Catastrophic Catalyst Failure".
    Gut your uppipe, or replace, and you should probably be good.
    I work on vehicles that make 650hp and 2400ft/lbs.
