Jerking occasionally while cruising?
Results 1 to 7 of 7
This is a discussion on Jerking occasionally while cruising? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Cruising on the highway today, and my Rex would shudder/jerk for a split second every now and then. I was ...
    Registered User RexNEffect's Avatar
    Dec 2008
    Question Jerking occasionally while cruising?
    Cruising on the highway today, and my Rex would shudder/jerk for a split second every now and then. I was thinking it might be because I was getting low on gas (just above the E mark), but there was no low fuel light (if there even is one). I found the closest gas station, put in some STP fuel cleaner, and filled it up with 11 gallons of 91 octane. It hesitated again on the way home, so I'm hoping it was just some gunk at the bottom of the tank.
    Any ideas? Is there a low fuel warning light (it's 2 degrees out, and am too lazy to go check the manual)?
    New owner of '07 WRX TR. Modest newbie modder, until I'm hooked and the warranty is gone.
    Registered User efmd3's Avatar
    Jun 2006
    the ham
    I've jerked once or twice while driving, but never in a manual...
    Dec 2008
    That would be the good kind of jerking. I'm not getting any pay-off from this one.
    May 2007
    behind the wheel
    check/clean the MAF sensor.
    Rogan o_0
    Dec 2008
    Checked the air filter box, and there was a little bit of ice/slush at the bottom. Removed it and have driven about 150 miles with no hiccuping... we'll see how it goes.
    Jul 2008
    PA
    Fuel pump
    look into getting a new fuel pump. This happened to my 03 wrx on my way home from one of my trips and stopped for a while then continued later on. Once I replaced the pump, I had no more problems.
    Mr. Towers
    May 2007
    behind the wheel
    Quote Originally Posted by RexNEffect View Post
    Quote Originally Posted by cool View Post
    Mr. Towers
    I've seen/heard this issue, many times, as well. But appears his issue was crap in the airbox.
    Rogan o_0
