Severe Hesitation, Please Help!
Results 1 to 8 of 8
This is a discussion on Severe Hesitation, Please Help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi there. I just registered and dont know how to use this site properly. My Impreza TS 2002 is Hesitating ...
    Dec 2008
    Ottawa Canada
    Question Severe Hesitation, Please Help!
    My Impreza TS 2002 is Hesitating and jerking in low RPM, burns more gas than usual and codes P0172 and 1137 came up.
    It works fine on high speed.
    I would appreciate any help in an easy understanding English.
    Fuji, Ottawa/canada.
    May 2007
    behind the wheel
    P1137 Front oxygen (A/F) sensor circuit range/performance problem
    P0172 Fuel trim malfunction (A/F too rich)
    Replace front O2 sensor
    Rogan o_0
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties - 750 lb/ft
    Registered User 03CrazyTaxi's Avatar
    Jun 2008
    St. Louis
    Front o2 sensor, +1
    Pretty easy to change if you can get the old one off.
    VF34'd Corvette Killer
    Bugeye Mafia Member #188
    May 2007
    behind the wheel
    Downside: it ain't cheap.. 150-180$ for it.. And it's tight to get to, but accessible from the pass. wheelwell. Take the plastic trim cover off to access it. 22mm I believe.
    Rogan o_0
    Dec 2008
    Ottawa Canada
    Thanks
    Thanks for the help, now I can ask my Mechanic to fix that. To late to do it now. its -20 now and cant wait till next summer.
    Thanks.
    Feb 2010
    Midlands, UK
    CAI's Suck (water)
    Do you have a cold air induction kit ???
    Jun 2007
    AL
    same prob
    i have the same problem on '04 STI only no codes. the car jumps until turbo starts to spool and never has problem under fool load. i cleaned the MAF and visually checked for boost leaks but need to get the tool. i should also check a/f ratio. Changed plugs only because it was bout that time anyway. i have CAI but has no leaks there. also i have 3" TBE, any other suggestions?
    Feb 2010
    Surfthacurl, did you ever figure out what was wrong with your car? Mine started doing the same thing yesterday. It died on the highway and now its sputtering until it spools up then its fine.
