WRX Doest not start
Results 1 to 7 of 7
This is a discussion on WRX Doest not start within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Howdy, I have a K REG Japanese import WRX that cranks over but does not start. I have changed fuel ...
    Nov 2008
    WRX Doest not start
    Howdy,
    I have a K REG Japanese import WRX that cranks over but does not start. I have changed fuel pump, ECU and also getting a spark and getting air. Anything else you can suggest it could be?
    Aug 2008
    Kennett Square, Pennsylvania
    how many miles are on the car? any mods? what year? lets see..if your sure you have spark,fuel and air than maybe....clogged fuel filter?, cam/crank sensor?, are the timing marks on is the t-belt ok?....is it a normal crank? fast crank? slow crank?
    Jul 2004
    Seattle, WA
    Did this start happening before or after you changed the fuel pump? What one did you use (stock or Walbro?)
    Registered User Acrdys's Avatar
    Jun 2007
    Lemore
    my friend just said..
    "just tell him to roll it down a hill drop the clutch and go WOT."
    Hawk-Eye Alliance#8089
    MODS LIST
    Nov 2008
    It just suddenly cut out and would not start again. Found fuel pump was not pumping fuel so changed it with another stock pump and getting fuel this time but still no start. Seems like a normal crank, only mods is a turbo timer and piggyback superchip. Car is a K REG 1992. Checked timing belt and seems to line up correctly. I am baffled as it is getting fuel, air, and spark but not firing. Diff ECU not worked either. I thought that if it was crank/cam sensor it would fire but just run lumpy?
    Cheers
    Administrator
    May 2003
    Check for injector pulse.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Super chip piggyback could be not outputting a signal or fried. I have had it happen with piggyback units before. You can try removing it and seeing if it will fire.
    Also check all your fuel pump and injector relays.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
