p1507 problems with a really bad oil leak
Results 1 to 6 of 6
This is a discussion on p1507 problems with a really bad oil leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a 03 wrx and i have that horrible p1507 of course i replace every single sensor including the ...
    Registered User evoeater1985's Avatar
    Nov 2008
    highlands ranch colorado
    i have a 03 wrx and i have that horrible p1507 of course i replace every single sensor including the ICV but i replace the TGV sensors the TPS, MAF new gasket on the throttle body even a new valve for the wast gate i almost replace my Intake manifold
    so please if any one knows whats going on let me know what the hell is going on thanks
    now i have a really bad leak to go with it all and it leaks so bad that im out of oil after a month of driving and when my car worms up it starts to smoke ALOT!! so HELP!!!!
    Jul 2004
    Seattle, WA
    Welcome to ClubWRX, sorry these problems are what brought you here, but I hope we help you fix it up.
    Sounds like a real mechanical problem, not a sensor issue.
    Do you have oil in your water or Water in your oil? If so could be a bad head gasket.
    Have you had the compression checked? Maybe your rings are failing, and are letting oil get in to the combustion chamber.
    What mods do you have? What Oil do you run?
    Is Oil leaking on to the ground? If so where is it coming from?
    Nov 2008
    well i hope its not but there is no mods that i know of it might be some from the pervies owners but i dont have any mods i cant tell if i have water in my oil but i do blow blue smoke witch tells me i have a bad ring? and i really hope its not a head gasket that would suck so bad,
    when i got the car they said they replace the cluch and the crank saft and also i had a really bad raidado leak so much crap and i run the oil it tells me to run
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Quote Originally Posted by evoeater1985 View Post
    Where is the radiator leaking from, might be the reason for the smoking. Take some pics of the locations and we can help get it resolved or at least direct you somewhere.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Nov 2008
    Yeah the leak is comring from the radiato at the bottom of the unit as far as I can tell and the smoking is comefrom my exhost mannadould I think now my turbo sit above it. So I don't know the Leak is coming from.but underanesth the car I thin its leaking above the oil pain
    Jul 2008
    San Antonio
    My thought is, find the radiator leak first. Might just be a hose or a clamp (buy t-bolt clamps if using silicone hoses).
    So the smoke is not coming OUT the exhaust ?
    N-swinger
    2000 Escort
