Hey all I got a 02 WRX. She fired up ok the other day moved 6 feet and quit and that was it. Initial diagnosis showed no fuel pressure. What I do know is that the pump will work when i put power to it directly from a battery, but otherwise no. Anyone know what I should look at? and how I can test the relay and the fuel pump controller? and also I've see ECM mentioned in other threads, how can I tell if its telling the pump to turn on?
