Mobil 1 syntech problem - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
This is a discussion on Mobil 1 syntech problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; People often neglect basic maintenance when it comes to some things, such as checking adjustment thresholds of things like cables. ...
  1. #31
    Registered User Venom351R's Avatar
    Oct 2010
    Maine
    People often neglect basic maintenance when it comes to some things, such as checking adjustment thresholds of things like cables. My first RR was a new 05 and I had it for 2 years and never had to adjust anything on it b/c when I sold it it had less then 10K on it. My current 06 RR had 24K on it when I picked it up last summer so Ive been more focused on doing all the little things now maintenance wise to make sure it runs and rides for as long as I want to have it. I'm going to have the valve clearance check done later this spring and I'll have them make sure all the things such as the cables are all in spec of the "free play" guidelines.
    2016 WRX Premium / Short Throw Shifter
    2007 STI Sold
  3. #32
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Rambo View Post
    It's a sliding scale. Colder/temperate climates should use 5W30 year-round. In warmer regions like SoCal or AZ (i.e. not Maine), or if the car sees hard use, Subaru recommends 10W30 due to the warmer ambient temperatures. The manual has a temperature scale which indicates which flavor to use. I think anyone in the NE should be using 5W30.
    The manual says 5w30 unless used in extreme environments then it says 10w40. When I lived in the desert I used 10w40 9 months out of the year.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  4. #33
    Oct 2010
    Maine
    Not sure if the winter here would be considered extreme or not but the dealership has never said anything about running other then 5W in it since I've had it.
    2007 STI Sold
  5. #34
    For winter use look at cold pump specs on oil manufacturer sites. If you're curious put some oil in a beaker, set your freezer to -20C, and leave the oil inside for a day. Then see how it pours compared to room temp oil. Or just forget about it and use a 5W anywhere below the arctic circle.
    - Al Stewart
  6. #35
    Oct 2010
    Maine
    The coldest it tends to get here is in the - Teens, we do get colder snaps then that but its usually not prolonged. Most of the winter here its above 0
    2007 STI Sold
  7. #36
    I suspect a synth 5W would be fine in those temps.
    - Al Stewart
  8. #37
    Oct 2010
    Maine
    Thats pretty much my conclusion as well
    2007 STI Sold
