Help with a CEL
Results 1 to 2 of 2
This is a discussion on Help with a CEL within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; After fixing a boost leak I took my car for a drive and got on it to see how it ...
    Apr 2008
    Maryland
    Help with a CEL
    After fixing a boost leak I took my car for a drive and got on it to see how it was running. While doing so My boost gauge shot up to 25psi where I then let off. The CEL came on and I checked it and its the wastegate solenoid. Some help on what needs to be fixed would be great. .
    My Main mod is Cobb AP stage 2
    Any help would be great
    Jeff
    03 Bugeye
    May 2007
    behind the wheel
    check the connection at the EBCS?
    Vac. lines good/connected/proper routing?
    verify voltage/grounding on the solenoid connector.
    sounds like it's stuck, maybe. you can 'test' the solenoid operation with 12v/grnd on the solenoid terminals, listen for it clicking
    Rogan o_0
