Intermintent boost fluctuation
Results 1 to 6 of 6
This is a discussion on Intermintent boost fluctuation within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Having problem with boost fluctuation. Boost bounces between .12 and .06, but not all the time. Sometimes I can let ...
    Feb 2008
    So. Jersey
    Having problem with boost fluctuation. Boost bounces between .12 and .06, but not all the time. Sometimes I can let it build slowly(roll on throttle) and it will hold at .1 until I shift. Sometimes it won't and starts to bounce. I cleaned the boost controller, and can hear it working(faint click when 12 volts applied). Cleaning changed nothing. The car used to boost fine till about 2 months ago, and had been getting slightly worse.
    Car is a stock 2003 except for XS intercooler hoses, Prodrive axle back, and K&N drop in. I don't hear any boost leaks when its on boost. Seems like the boost controller can't cope with boost building too fast, over shoots, then can't catch up. Was going to replace the boost controller, but wanted to run it by you guys for any other ideas first. Would adjusting the waste gate arm fix this? Sorry for the long post, but any help is appreciated.
    Registered User NjBuGeyEdWRX's Avatar
    Apr 2007
    Beachwood NJ
    what mbc do you have?
    03 WRB WRX STAGE II
    STi COMING SOON
    BUGEYE MAFIA #199
    LET ME QUOTE THE LATE COLONEL SANDERS " I'M TO DRUNK TO TASTE THIS CHICKEN . . ."
    Oct 2005
    Late Devonian
    Quote Originally Posted by boll58 View Post
    I would suspect the boost control solenoid. If you can find someone to swap theirs in for a minute you can tell that way.
    It is not going to be fixed with an arm adjustment.
    Quote Originally Posted by NjBuGeyEdWRX View Post
    None I assume.
    Feb 2008
    So. Jersey
    Well I swapped the FBC today, and no change. Also replaced all the vacumn lines involved in the boost controller. I am at lost now. Could the waste gate acuator be bad? I unhooked the waste gate arm and the waste gate moves freely.
    Oct 2005
    Late Devonian
    Is the pill in there?
    Feb 2008
    So. Jersey
    Yeah the pill in still in the hose from the turbo outlet to T. I didn't change that hose because is was still flexible. I took a lot of preload off the waste gate arm, and that didn't change a thing either. Tomorrow I'll try adding more preload to see if it changes anything. I'm also reseting the ECU after each change I'm making.
