misfire cylinder 2 & 4 help plz. new guy here.
Results 1 to 10 of 10
This is a discussion on misfire cylinder 2 & 4 help plz. new guy here. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a wrx 03 and get a misfire in cylinder 2 and 4. what are the basic things to ...
    Registered User fmoises's Avatar
    Oct 2008
    los angeles, ca
    Question misfire cylinder 2 & 4 help plz. new guy here.
    i have a wrx 03 and get a misfire in cylinder 2 and 4. what are the basic things to change to fix this problem?
    Moderator
    Jul 2003
    Maryland
    Check the coil packs...then the plugs...
    Oct 2008
    los angeles, ca
    mmmm i dont want to sound dumm.. but im new. what am i checking for i should i just replace them? what side of the engine are cylinder 2 and 4?
    Jun 2008
    if youre looking in the engine bay the cylinders go like this
    3----4
    1----2
    im pretty sure
    this is what you do
    get new spark plugs, and swap the coil packs from the drivers side to the passenger side, thats what i did and it made my misfire go away, in case you dont know, the coil packs are the little packs that go on top of your spark plugs, they have a plastic clip on the wires so you can move them to another cylinder, youre gonna have to remove your intake, battery and maybe a few other things depending on what tools you have and how big your hands are
    Oct 2008
    los angeles, ca
    ok.. thanks ill do that this week ill let you know what happens.
    Jun 2008
    Quote Originally Posted by fmoises View Post
    it wont be the easist thing getting the plugs in and out, just make sure to take your time on it
    Aug 2008
    Kennett Square, Pennsylvania
    i ran into a problem very similar to this on my Legacy a while back....when you get the chance make sure the correct plugs are going to the correct fuel injectors.....apparently the previous owner did the head gaskets and plugged the wrong connector into the wrong fuel injector.....but i guess if you havent had any recent work done this shouldnt be the cause......but nonetheless something easy to check.....
    Oct 2008
    los angeles, ca
    Ok, so i did the spark plugs yesterday and the car is running good, maybe just a little to low idle rpm but i dont mind. I let you guys now if my cel come on again.
    Oct 2008
    los angeles, ca
    Ok. So the code came back!! But no worries i took it to the dealer and they told me it was a problem with the computer giving me wrong information and that it could be patched. That its a very common thing in the wrx 03 models.
    Registered User dforce's Avatar
    Aug 2005
    22,405 and 605 intersect
    So how much was the repair?
    08 STi DGM
