Removing stock intake
Results 1 to 5 of 5
This is a discussion on Removing stock intake within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have searched google, this website, and others endlessly and cannot find anything on removing the stock intake from a ...
    Registered User Black X Dahlia's Avatar
    Apr 2008
    baton rouge, la
    i have searched google, this website, and others endlessly and cannot find anything on removing the stock intake from a wrx sti. I have all the piping from the box to the elbow removed, but getting it removed from the turbo on back looks very hopless without removing coolant lines, harness's, and the intake manifold. i have read alot of posts on this websites that make this task seem very easy, but i have no clue how this task could be done the way it has been described by various ppl.
    P.S.- Im trying to remove the entire intake
    How Fast Can You Afford To Go?
    Aug 2008
    Kennett Square, Pennsylvania
    wow....i didnt know this either...i just looked in the factory service manual for my 02 WRX and it says...
    1) Disconnect the ground terminal from battery.
    2) Remove the intake manifold. <Ref. to FU(D0HC
    TURBO)-1 5, REMOVAL, Intake Manifold.>
    3) Remove the sensor, engine harness, and fuel
    pipe attached to the intake manifold. <Ref. to
    FU(D0HC TURBO)-21, DISASSEMBLY, Intake
    Manifold.>
    4) Remove the intake duct from intake manifold.
    Moderator Donkey's Avatar
    Da boonies,Va
    Do you mean the turbo inlet pipe?If you are removing it to replace it with a silicone one you gotta cut one of the nipples of the back so you can slip the inlet out the front without removing the intake manifold.Try searching "turbo inlet install"
    2002 FORESTER S
    1998 FORESTER S
    Apr 2008
    baton rouge, la
    No im attempting to remove the entire intake to perform a boost leak test, and then re-install the intake.
    Apr 2008
    baton rouge, la
    Manifold.>
    haha i knew it. Ok well know i think im pretty caught up. I was fighting it, trying to find a way to remove it without removing the intake manifold and harness
    Thanks for the info
