Engine mount advice on a 1994 WRX!!!
Results 1 to 6 of 6
This is a discussion on Engine mount advice on a 1994 WRX!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all, I have noticed that my engine wobbles more recently on start up as alot once it is turned ...
    Jan 2008
    Red face Engine mount advice on a 1994 WRX!!!
    Hi all,
    I have noticed that my engine wobbles more recently on start up as alot once it is turned off, the wobble can be felt inside the car aswel.
    While driving if im cruising along in 1st gear and do a gear change to 2nd once i bring the clutch back up i get a knock as if the engine or part of it is kncking against something.
    Am i right in thinking this is a worn engine/transmission mounts??
    also how costly would this sort of problem be??
    any help appreciated!!
    Thanks in advance peepl!!
    Jan 2008
    Any one got any ideas??
    or has no one ever had such a problem??
    Jan 2008
    I dont know why, but i get the feeling its more the tranny mount rather than the engine, as when i feel the knockin movement the gear lever moves up and down.
    any 1 had this sort of problem???
    Registered User atrizzzie's Avatar
    Sep 2008
    Seekonk, Massachusetts
    you probably need some motor mounts and a trans mount. pop the hood n rev the engine and see if thats the case. it will probably cost a couple hundred for parts
    Jan 2008
    oh right i see, would you recommend the standard part or should i get a more expensive part??
    Jul 2004
    Seattle, WA
    The standard part is the one installed in the car now. It lasted 14 years. So I'd say go for that one again.
