Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on Radiator go boom? **w/ Pics within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just looked that up right now. I'm pretty new to the site. Sorry... anyways I am going to install ...
    Registered User onekrissy1's Avatar
    May 2010
    CALI
    lol
    I just looked that up right now. I'm pretty new to the site. Sorry... anyways I am going to install a radiator on my 2005 WRX.
  2. #17
    Registered User STI_KLR's Avatar
    Dec 2007
    The taint of Northern Virginia.
    Rogan: Live simply, love generously, care deeply, speak kindly.
    Mods List Build Thread
    Bugeye Mafia #196 High Mileage Club
    Fully Built EJ257 HYBRID & JDM STI 6-Speed
    Miniature Awesomness
  3. #18
    May 2010
    CALI
    photo of problem
    What a mess!
  4. #19
    I wonder if that is your second radiator. The hose clamps are not Subaru parts.
  5. #20
    Jul 2004
    Seattle, WA
    Please tell me you are not going to install another stock/plastic top/bottom cap radiator.
    For about the same amount as a stock one you can purchase an aftermarket all aluminum one.
    Gimmik Motorsports, Koyo and Mishimoto make good, all aluminum radiators.
  6. #21
    Registered User FyrHazard's Avatar
    Mar 2010
    Iowa
    Old thread bumps are good. Means people are searching
    What are you guys using for a lower radiator cap if you still have one? My car has an Aluminum radiator, but it has the radiator cap as well as the one on the reservoir. Is this supposed to be a different pressure setting than the reservoir? (yes, probably should have searched for this, but it seems like a good place to have the answer posted.)
    "Good design is a lot like clear thinking made visual." - Edward Tufte
    Bugeye Mafia #314
  7. #22
    The pressure of the system is dictated by the failure pressure or opening pressure of the component that fails or opens first. This means the system pressure is dictated by the pressure at which the weakest hose, clamp or radiator seam, or the lowest-pressure-rated cap, opens. Localized pressures can be higher depending on the state of the system (ex: when the thermostat is closed) but overall, the lowest-rated cap will dictate the general pressure.
  8. #23
    May 2010
    CALI
    Red face Bummer!
    Unfortunately I am installing one that is stock that has the stupid plastic tank on it. I could not afford the aluminum one. Plus all I found was one on summit racing for $440. I picked this one up for $140. Believe me if I have more trouble or can afford an aluminum one I will put that in. The hose clap is new. It was leaking there before and when I tightened it then the actual radiator started to leak like I showed in the pic...
  9. #24
    Dec 2007
    The one I replaced mine with was the CXRacing brand off of ebay for $160 shipped to my door. Still keeping her cool very nicely
    And it's hard to believe my engine bay used to look like that! It looks nooo where near that anymore
  10. #25
    Dec 2007
    It doesn't even look like THIS anymore! But this gives you a good angle of the radiator!
