boost dissapeared~~!
Results 1 to 12 of 12
This is a discussion on boost dissapeared~~! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 04 wrx wagon, big top mount, bov,megan headers and up pipe, turbo back exhaust, cobb ap stg2 my car was ...
    Registered User WRXwagonMAFIA's Avatar
    Aug 2008
    some old backroad
    my car was running fine, then on break from school went to go get something, and there was no boost being produced, none at all. wastegate is not stuck open, and my boost guage is now reading -1.7 psi WOT. what could have happened? and is this just a good reason to upgrade?
    72k on the car by the way factory turbo
    04' WRB wagon stage 2
    wagon Mafia #1 Where my wagons at?
    Registered User ansonowicz's Avatar
    Oct 2005
    LBC
    Quote Originally Posted by WRXwagonMAFIA View Post
    If you have the time/tools, I would suggest removing the downpipe and taking a look at the outlet side of the turbo. You might not be able to peek into there, so a quick picture might work also. Using your hands, you can spin the wheel to see if it moves freely or not. I'm not saying that is DEFINITELY the problem you're experiencing, but with a little bit of time & elbow grease you can tell for sure.
    Same thing happened to me when I was at the track:
    F4.21 have root access, will travel
    :wq! 6MT20G
    Quote Originally Posted by volcomsoldier19 View Post
    long haul, the wagon will give you happiness in the times of madness...
    Aug 2008
    some old backroad
    what would cause a blade to break like that or to seize up in the turbine housing. i do have the time tonight and i will check that out. but i would like to know any other possibilities. and will it damage my car more if i continue to drive on it while the turbo is out of commission?? i would like to not cause any more damage
  5. #4
    A simpler possibility, provided you are seeing zero boost: On the wastegate arm there is a C-clip. This needs to be removed to adjust the wastegate arm (as in, when one uses a Cobb product to reflash and then has to set target boost). My bet is that the C-clip is now missing.
    Check the wastegate actuator arm and make sure the clip is not only present, but engaged.
    - Al Stewart
  6. #5
    Oct 2005
    LBC
    There's no real physical danger to driving like that. The ECU will be pissed off it's not getting the air/fuel ratio it wants. Other than performing poorly, it's relatively safe for the motor (maybe not other motorists when your merging doesn't go so well). I got a whole 8mpg and was running rich as hell.
    In my case, it was combination of 60k+ miles on a 20g and oil starvation. I believe the oil starvation caused the bearings to seize up, warp the wheel, and the blades made contact on the walls of the turbo.
    :wq! 6MT20G
  7. #6
    Aug 2008
    some old backroad
    the c-clip is still present. my ol is reading full.
    thanks for the help guys, when i check it out at home tonight i will let you know what i find, i may just use this as an excuse for a new turbo though.
  8. #7
    Oct 2005
    LBC
    Good luck and happy hunting!
    :wq! 6MT20G
  9. #8
    May 2007
    orlando flawduh
    im not good with stuff like this but could it possibly be that the cobb stage II map notes do not match up with the mods that you currently have? (bigger TMIC, bov, headers) and now your ECU is pissed off because of it?
    just a guess.
    desiree
  10. #9
    Oct 2005
    LBC
    Quote Originally Posted by wrxtreme06 View Post
    just a guess.
    Sorry about the misunderstanding. I meant to say MY ECU was very pissed off when my turbo failed because there wasn't enough air coming in. So more & more fuel was pumping in trying to figure out why the turbo wasn't doing it's job.
    In the event the OP has a complete turbo failure, the ecu might try to compensate by making fuel changes to accomodate thus getting uber pissed Nevertheless, it's still relatively safe to drive.
    :wq! 6MT20G
  11. #10
    May 2007
    orlando flawduh
    Quote Originally Posted by ansonowicz View Post
    oh, i was talking to the OP, not you =P
    whole bunch of confusion up in this thread haha
    desiree
  12. #11
    Oct 2008
    nj
    check your actuator hose, your tmic might be hitting the actuator (check for damage).also check any hoses that are related to the boost system. check the actuator arm or the bar that open and closes the waste gate...good luck!!
  13. #12
    Registered User scott s's Avatar
    Dec 2008
    va
    check and make sure your sensor in the up pipe didnt break off and go into the turbo just suggesting
