rear wheel bearings
Results 1 to 3 of 3
This is a discussion on rear wheel bearings within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have to do the 2 rear wheel bearings on my 02 wrx can someone tell me what parts i ...
    Apr 2008
    Albany
    rear wheel bearings
    i have to do the 2 rear wheel bearings on my 02 wrx can someone tell me what parts i need is it a whole hub assembly or just bearings or what i havent done wheel bearings befor but i shoouldnt be as hard as the uppipe dp install obv. are there part #'s and or a good place to buy them fill me in with tricks and tips
    2002 PSM WRX 5mt Hella Slammed/Turboswapped/DomTuned/Daily RIG
    Aug 2008
    Kennett Square, Pennsylvania
    well you can do them yourself but...subaru dealerships have there own hub and bearing set which makes it 10x easier....anyways i believe you need 2 bearings(if your doing both sides) and i believe there are 3 seals for each side 1 in the front and 2 in the back....
    Oct 2008
    I believe there is one bearing each wheel with 3 seals per bearing that should be changed. 2 inner seals, 1 outer.
