changing oil and types?
Results 1 to 15 of 17
This is a discussion on changing oil and types? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; alright so ive been told to use mobile 1 for the car... but when i went to the store there ...
    Registered User sicksynergy's Avatar
    Jan 2008
    NJ
    alright so ive been told to use mobile 1 for the car... but when i went to the store there were different types... 40-10 or something. i was wondering what type of oil i should use?
    if i were to change it myself, would anyone know a website that can give me a tutorial on how to change oil in an 05 sti?
    thanks =)
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Look in your owners manual for manufactures recommended oil weights. Or you can even just pop the hood, it says right on the oil filler cap it's self.
    A complete n00b's guide to changing the oil in your WRX (with pics!) - NASIOC
    Jan 2008
    NJ
    whoop alright thanks =)
  5. #4
    Apr 2007
    8000' up in Colorado
    Here's a tip for you: Go to Walmart to get your oil. They sell 5 quart jugs of Mobil 1 for $22-23, and the filters are also a couple of bucks cheaper than your local auto parts store. This will usually save you about $10 over the auto parts store where you can only get the oil in quarts for $6+/quart.
    Your car has a 4.8 quart oil capacity so you can just pour in the entire 5 quart jug of oil. There's no need to pre-fill the oil filter as it says in the instructions the person posted above either. It's just an unnecessary step that adds a couple of extra ways to make a mess!
    It's key to use a Mobil 1 oil filter (or one with similar performance) instead of the standard filter. The standard filter or any cheap filters will only have a 5k mile life as opposed to the Mobil 1 filter that can easily go 10k miles. Since you can go 8-10k miles with synthetic oil, you need a filter that can go more miles.
    You may also burn some oil. I use about a quart every 3k miles. People are all over the place on this and it doesn't seem to matter how you drive or anything like that, it just seems to be that some engines burn oil and some don't, and everything through the spectrum in between too. This actually extends my oil change interval though since I'm adding 20% new oil including all the additives and things the car needs. So here's an example of my oil change schedule:
    45k miles - Replaced oil and filter - Mobil 1 5w-30 and Mobil 1 M-108 filter
    48k miles - Added 1 quart Mobil 1 5w-30
    51k miles - Added 1 quart Mobil 1 5w-30
    54k miles - Replaced oil and filter - Mobil 1 5w-30 and Mobil 1 M-108 filter
    For all of you people that insist oil must be change every 3k miles, please keep in mind the recommended oil change interval on a Porsche 911 is 20k miles with Mobil 1. At 3k miles Mobil 1 is just getting warmed up.
    Scott
  6. #5
    Castrol Syntec (5qt, Walmart) + OEM filter (I buy 6 at a time through the local parts manager who's a friend) = $25 / oil change
    This is about the easiest thing you can do with your car, other than drive/wash it. Consider any shop will charge you $50+ for an oil change with synthetic (if not more), this is an easy way to save some $$.
    As for the interval, IIRC, Subaru recommends an oil change every 3,750 miles on their turbocharged engines. Personally, when I hit the 3,000 mile mark, I make a mental note that sometime when I'm near Walmart to pick up oil. This often means I do it every 3,300-3,500 miles.
    Get a set of RhinoRamps, an oil pan, and an oil storage container, and you're all set.
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  7. #6
    DUB
    DUB is offline
    Jul 2007
    SLT, CA
    What does your TBN from Blackstone look like after that 9k change interval?
  8. #7
    Apr 2007
    Quote Originally Posted by DUB View Post
    Please don't try to lecture me on when/why I should be changing my oil. Brand new oil doesn't lubricate any noticeable amount better than somewhat dirty high quality oil well within its mileage/usage limits. Since I've replaced 40% of my oil within that 9k miles, and I'm using one of the best oils available that has additives good for well over double that 9k miles, I'm sure my TBN is very good. The color is good when I change it, and I also use the best filter available on the market with over 98% filtration efficiency, as compared to the ~92-94% efficiency of the stock Subaru filter or pretty much any other inexpensive filter.
    Scott
  9. #8
    I think it's actually a legitimate question though. The answer is legitimate too -- I think at least theoretically the 5/10W-30 stuff is going to end up with a comparable, if not better TBN when all is said and done than the much more robust 5W-40 I use, exactly because of all the topping up.
    From what I've seen on other motors TBN of the 5W-40 (Delvac1 or M1 TurboDiesel) is marginal at 7,500 mi, but most EJs don't drink much of that stuff so people tend to not top off as much as others using a xW-30 M1.
    The real concern with going long on a turbo Subaru post 04 for 2.5L motors is the known screen issue, and topping off won't address that. If my motor were a 2.5L turbo I'd use a shorter drain interval than I do now with the 2.0L (I've settled on 5K or whenever I remember, whichever comes second).
    Les jeux sont faits.
  10. #9
    DUB
    DUB is offline
    Jul 2007
    SLT, CA
    Lecture? I think you are confused. I asked you a question because I wanted to know the answer. So your answer is "I haven't done one", correct?
    I could care less when you change your oil, it's your car. So you change your timing belt every 75k and your oil every 9k, whoopdy-do.
  11. #10
    Apr 2007
    Wow somebody that actually supports my point of view (even if not 100% ). That doesn't happen often. I assume by the screen issue you mean the filter in the turbo feed line? I removed that filter in my car so I don't have to worry about that issue.
    My apologies, I misinterpreted your tone. Most people don't believe the oil and filter perform perfectly well at that interval.
    And no, I haven't done one. I have an excellent source for Mobil 1 performance data (direct line to their development engineers) so I have faith in how I use it.
    Scott
  12. #11
    DUB
    DUB is offline
    Jul 2007
    SLT, CA
    cool
  13. #12
    Do you recall from the TSB or some other info source if there are other screens to worry about? The turbo feed line would explain turbo failures but there were also motor failures and I could swear there were other screens (but memory isn't my strong suit).
    BTW, do you recall the sump size for the 911? A higher capacity will increase the drain interval.
  14. #13
    Jan 2008
    NJ
    Tsb?
  15. #14
    DUB
    DUB is offline
    Jul 2007
    SLT, CA
    You're thinking of the screen for the AVCS. It usually alerts the owner via a rough idle, giving plenty of warning before it causes any major engine damage. So, less catastrophic than the 'other' screen getting clogged. (or so I have read)
  16. #15
    DUB
    DUB is offline
    Jul 2007
    SLT, CA
    Quote Originally Posted by sicksynergy View Post
    Tsb?
    Are you asking what a TSB (Technical Service Bulletin) is or are you asking to be shown the TSB in question.
