Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
This is a discussion on changing oil and types? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; oh i was asking what it was lol...
    Registered User sicksynergy's Avatar
    Jan 2008
    NJ
  2. #17
    Quote Originally Posted by sicksynergy View Post
    Tsb?
    Inside this link there is a discussion and a link to another thread, that links to another thread and so on. If you get bored, stop reading and change the oil with the correct type at 3750 mi if your motor is 2.5L turbo and/or has AVCS.
    Oil TSB for 2006+ Subarus
    Quote Originally Posted by DUB View Post
    You're thinking of the screen for the AVCS. It usually alerts the owner via a rough idle, giving plenty of warning before it causes any major engine damage. So, less catastrophic than the 'other' screen getting clogged. (or so I have read)
    Ah, thanks. I actually remembered discussing stuff with 302 way back when it first came out and I suspected there was some underlying reason for all the "built" 2.5Ls going boom.
