Why does my wrx run sluggish when my gas tank is less then half?
Results 1 to 14 of 14
This is a discussion on Why does my wrx run sluggish when my gas tank is less then half? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi Everyone I have a 2003 WRX with 52,000 miles and I notice that it drives excellent when the gastank ...
    Sep 2008
    Illinois
    Hi Everyone
    I have a 2003 WRX with 52,000 miles and I notice that it drives excellent when the gastank is completely full. But once I have less then half a tank it feels sluggish and underpowered? What can I do to fix this?
    Thanks
    Registered User Irish_car_B0MB's Avatar
    Mar 2008
    NOR*CAL Rohnert Park, Cotati Area
    Quote Originally Posted by jbravo View Post
    Hi Everyone
    Thanks
    Maybe you had a bad tank of gas in the past and havent used it all up yet. Also maybe try some fuel system treatment. Or maybe its all in your head. :lol:
    May 2007
    orlando flawduh
    Thanks
    keep your gas tank more than half full
    desiree
    Sep 2008
    Illinois
    Thanks for the help guys. But I also notice that the car drives rough when its cold in the morning. Is there a way to adjust the fuel pressure? Could that be the issue?
    Apr 2007
    8000' up in Colorado
    It sounds like either your fuel filter is clogged or your pump is going (or both).
    Scott
    Sep 2008
    Illinois
    I think your right teflon Jones. The car runs great with a tank full of gas. I think a tank full of gas provides high fuel pressure. Once the tank is less then half, the fuel pressure drops which might cause the car to run rough and under power. Is it a pain to change the fuel pump and fuel filter? Should I reset the ecu now that the temperatures are around the 30s?
    Registered User wrx0131's Avatar
    Jul 2007
    Yonkers, NY
    fuel pump is easy....just put your back seats down and its located in the trunk......i believe fuel filter is easy too.....but a way to check if your fuel pump is bad is to listen while your car is idle if your fuel pump makes any weird noises.....when my fuel filter was dirty my car ran rich and would stall at red lights......it eventually messed up my MAF sensor and my car then ran rich.....burnt my 2 of my pistons.....and yea you get the idea....so just make sure you get that checked out
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    it sounds like either your fuel filter is clogged or your pump is going (or both).
    +1
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Aug 2008
    Same problem
    My O4 is doing the same thing. Thought it was in my head at first but confirmed MPGs with half tank fill-ups vs full. Also, sluggish in the cold. Could it be water in the tank?
    Aug 2008
    Fuel pump did it
    Thanks for the great advice. Upgraded the fuel pump to a Walbro 255 and WOW what a difference. Not only am I getting consistent fuel burn but MPG went up to 28! Car runs smoother under power and has better low RPM throttle response.
    Maybe I'll keep this Subaru after all.
    Registered User T.J.'s Avatar
    Oct 2002
    on a boat...
    Good to hear that she is running better! You should probably replace the fuel filter under the hood too, just to be safe.
    It is a snap to do and only costs $20 or so to replace. Look at the corner of the engine bay that is closest to the drivers seat. It is the small black pot w/ two curved tubes sticking out of the top. It is just held in by a metal strap and the fuel lines that are attached to it.
    Later, T.J.
    200,000 mile club.
    Old Irish adage: "Do not resent growing old. Many are denied the privilege."
    Aug 2008
    Thanks - did it already
    Changed the filter as part of my post purchase maintenance back in February.
    Apr 2015
    Never leave your vehicle's gas tank half empty.
    "Topping up" forces fuel evaporation. Don't confuse this concept with "topping off" which is overfilling the gas tank. Never leave your gas tank half empty! it increases water condensation in the tank. The more gas inside your tank , the less air inside. Air provides evaporation opportunities, which means lost fuel. Condensation clogs your injection system as well. Avoid fueling up when a fuel tanker truck is refilling the station. This process brings the dregs of the gasoline (impurities of dirt, sludge and the like) to
    the top and into your fuel source slowing down the efficiency of your car.
    lit fam XJman's Avatar
    Feb 2015
    At work
    Quote Originally Posted by jackbern View Post
    That is the most insane thing I've ever heard. If your gasoline is getting so much water in it from condensation at a 1/2 tank your car runs bad you've got a bigger problem.
