Question about my experience with my subaru
Results 1 to 10 of 10
This is a discussion on Question about my experience with my subaru within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi everyone, I was hoping to get some feedback with a certain noise i have been hearing in my wrx. ...
    Mar 2008
    hi everyone,
    I was hoping to get some feedback with a certain noise i have been hearing in my wrx. I own a 02 Wrx and i have the stock rims and tire ( michiellen). I notce a whoa whoa whoa sound when driving the vehicle but there is no shaking or drifting on the steering wheel. I'm afraid this is a serious problem or just simply the tires. Any suggestion will be deeply appreciated thank you. Thank you
    Oct 2005
    Late Devonian
    Quote Originally Posted by subie814 View Post
    hi everyone,
    Those are not the stock tires. BTW the stock tires were crap anyway though.
    Is the noise coming from all 4 corners or just one or two? It could be a bad belt on a tire - if you rotate the tires then you should hear it move location. Otherwise it could be your bearings or your cv joints (among other things).
    Mar 2008
    the noise is mainly coming from the front driver side tire. I bought the car used and these were the tires given to me by the dealer. Should i be highly concerned?
    Apr 2006
    Windsor, Ca
    Wheel bearing? CV boot/joint? Check underneath for grease spray.
    Blob Eye Syndicate #1000
    Oct 2005
    Late Devonian
    You should determine the cause. Rotate the tires and see if the noise comes from the back. If so, inquire with the dealer to see if you can get the tires warrantied. If it is not the tires I would definately follow up on it.
    Aug 2008
    Kennett Square, Pennsylvania
    when you have the car in the air to rotate the tires.....i would shake down the front end and see if you get any play.....3&9 for tie rod ends 12&6 for ball joints...and if you have excessive play in both directions chances are its a wheel bearing.....oh also im sure you have already done this but make sure your tires are inflated properly....
    Mar 2008
    thanks everyone for the feed back. It turns out to actually being the driver side wheel bearing. Any suggestions of a brand? Oem? tanaikin? thanks again for all the help
    Apr 2006
    Windsor, Ca
    I knew it!!! What do I win?
    Oct 2005
    Late Devonian
    Quote Originally Posted by langridge View Post
    Umm, I posted it before you so I get dibs on the winnings.
    Registered User Very-Rexy's Avatar
    May 2006
    Warner Robins AFB 30,000 feet
    thanks everyone for the feed back. It turns out to actually being the driver side wheel bearing. Any suggestions of a brand? Oem? Tanaikin? Thanks again for all the help
    oem.
    06 WRX - Deadbolt Zilla 20g 365AWHP//358AWTQ//TopSpeed
    STi Drivetrain installed by CRE
    Hawk-Eye Alliance #54
    My mod list
