Misfire all 4 Cyl
Results 1 to 4 of 4
This is a discussion on Misfire all 4 Cyl within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; But thats just what the check engine code read... the car in fact is not mis-firing I asked around and ...
    Registered User bugeye'd02's Avatar
    Sep 2008
    Misfire all 4 Cyl
    But thats just what the check engine code read... the car in fact is not mis-firing I asked around and was told there is a recall of sorts 2002 wrx need an ECU reflash... anyone go through this already??
    Jul 2004
    Seattle, WA
    You said in your clutch thread that you just had the engine replaced.
    Can you provide some details about that? Like did you pay a shop to do it? Did you get a warranty with the work? What Long block? Used engine?
    New Spark plugs? inspect coil packs?
    How many miles on the Fuel filter? How is your gas mileage?
    If you reset the codes (take the negative cable off the battery, pump the brakes, replace the cable, then run it) does the code come back right away?
    I know this is a lot of questions, but that's not a good code to have.
    Registered User DstrbdTech's Avatar
    Aug 2008
    I misfire on all 4...wouldnt you hear that...like constantly.
    Registered User wrxmuch?'s Avatar
    May 2008
    Nashville
    check your egt sensor, mine was broken and it caused misfires all over the place. I had a blinking CEL though.
    Cobb Accessport v1 stage 2 93 map, Nitto Invo Tires, Sti Front and Perrin Rear Sways, Rota Torque Wheels, APS Exhaust 3.5" turbo back. Catless TurboXS Up pipe, Goodridge Stainless Steel Brake lines, Hawk HPS Brake Pads, Paranoid Fabrications Cowl Braces, Group-N Tophats, Group-N Trans and Engine Mount, Tokico Dspec w/ Rce Black springs
