Is it the Alternator???
Results 1 to 8 of 8
This is a discussion on Is it the Alternator??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have this scratching/grinding noise (more grind than scratch)in the general area of the engine bay in the pic that ...
    Registered User p0rnstar19's Avatar
    Gaithersburg, MD
    i have this scratching/grinding noise (more grind than scratch)in the general area of the engine bay in the pic that increases and/or reduces with speed (picture not of my car, just a sample).
    i did a quick check of the belts and everything, but can't seem to locate it exactly.
    what could it be?
    Quote Originally Posted by LPPTundWRX View Post
    ^^^Your sig is bull****....
    Quote Originally Posted by Integra96 View Post
    Is that a euphemism for a meat helmet?
    Someone help me out here....
    While the belts are off check the rollers and the tensioning mechanism. Sometimes a helper pulley's bearings may fail.
    Gaithersburg, MD
    yea, i saw that one... but it's not like the whining noise he described. it's more like a scratching than a whine. i know it's not power steering because it doesn't affect the steering at all.
    when i turn the car on/off it rattles slightly and then i hear the scratching. if i can't get it to the shop tonight, i'll check it out as much as i can.
    OK I'd listen closely with the plastic covers off. If it's in that area still I'd remove the belts and check the tensioner pulley anyway.
    Gaithersburg, MD
    i found out what it was. it was the ac pulley. but thanks anyways sd gr! got a ur pulley set on the way.
    Excellent, good to hear it!
    Registered User penderperson's Avatar
    Jul 2007
    what exactly w/ the ac pulley was making the noise? was it the clutch or the pulley?
    post up your results please!
    05' Subie WRX
    Gaithersburg, MD
    it was shot... for now i just replaced it with a stock one until i get the pulley set in. not too expensive, they are about $45.
    it's that i was getting a scratching sound, i checked around with the belts off like sd gr said and i found out the direct cause. as it got worse it kind of sounded like i had a supercharger while i was driving... if that can explain anything.
