Brake light on idiot cluster
Results 1 to 3 of 3
This is a discussion on Brake light on idiot cluster within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey all, Quick question. I was driving to the bus stop for work today and I noticed the brake light ...
    Registered User rotorocker's Avatar
    Mar 2008
    Manalapan NJ
    Hey all,
    Quick question. I was driving to the bus stop for work today and I noticed the brake light on the idiot cluster came on. I didn't have my AP with me unfortunately. If I did, could I have pulled over and it would have told me the code? Also, I thought my pads still had some life left but could low pads throw the light? I'm going to check for brake fluid when I get home as I know a maybe going around a turn the level set the sensor off. It went off after only a couple minutes but if I can pull the code next time I will (I'm putting the AP back in the car tonight). If anyone has had a similar experience?
    Just remember, capitalization and punctuation marks the difference between, "I just helped my uncle, Jack, off a horse." and, "i just helped my uncle jack off a horse"
    04 Wrx Wagon Cobb Stage 2
    Blobeye Syndicate #026
    Quote Originally Posted by rotorocker View Post
    Hey all,
    No.
    If the fluid level drops the circuit is activated. The fluid level will drop when the pads wear and/or if there is a leak. Check the fluid level, find out why it's dropping.
    The brake circuit does not generate codes. The ABS circuit does, but that's not what you're describing.
    Mar 2008
    Manalapan NJ
    Thanks for the quick reply. I had a hunch that it wouldnt throw a readable code. I'll just check the fluid level when I get home and double check my pads. I've been wanting to upgrade to a set of hawk pads and it looks like now is a good time
