Problem holding boost in 5th gear
Results 1 to 10 of 10
This is a discussion on Problem holding boost in 5th gear within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This has happened 3 times.....all about 1 month apart. if im pushing it in 4th and shift to 5th get ...
    Aug 2008
    Naptown, MD
    This has happened 3 times.....all about 1 month apart. if im pushing it in 4th and shift to 5th get up to about 4000rpm and the boost will dump with throttle, and then the CEL will come on and cruise will flash then 2 start ups later it will go away and each time the code reads back to the wastegate, subaru doesnt really have any for sure suggestions for me...anyone else have this problem? Do i have to get an aftermarket wastegate? Im running Cobb tbe with cat, SPT heatshield, Cobb SR intake, and Cobb AP stage 2.
    06 WRX TR COBB stage 2
    Oct 2005
    Late Devonian
    Quote Originally Posted by bbjoy View Post
    It sounds like you are getting boost creep. There is a big sticky thread if you look. Usually it isn't a problem if you have a catted DP, but it sounds like the case. You can get your wastegate ported or just don't floor it from low RPM in 5th.
    Aug 2008
    Naptown, MD
    Thanks for the answer....any reason it is only happening in 5th gear?
  5. #4
    Oct 2005
    Late Devonian
    Highest load and extended time WOT.
  6. #5
    Aug 2008
    Naptown, MD
    So if i dont pound it in 5th while in low rpm's i should be fine?
  7. #6
    Oct 2005
    Late Devonian
    I don't have the issue, but that is what I have read.
  8. #7
    Aug 2008
    Naptown, MD
    do you know if there are any long term problems cause by this happening or is it just an inconvenience ?
  9. #8
    Oct 2005
    Late Devonian
    Yes there could be, but the system does a good job of protecting against it. Did you hit fuel cut? That sounds pretty harsh to me.
    I just re-read you original post, what do you mean by "boost dumps with throttle"?
    I think it would be well worth your time to read this and decide if this is the problem you are having:
    Boost creep / fuel cut
  10. #9
    Aug 2008
    Naptown, MD
    my car does not shut off...although it does lurch for a split second while i am on the gas (as if i got of the throttle) and then it goes on being just fine.
  11. #10
    Moderator Donkey's Avatar
    Da boonies,Va
    Have you tried calling Cobb about the issue?
    2002 FORESTER S
    1998 FORESTER S
