02 wrx possible bad turbo
Results 1 to 3 of 3
This is a discussion on 02 wrx possible bad turbo within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hello, all new here. have an 02 wrx 2.0 I believe the turbo is bad. here's what it is doing. ...
    Oct 2008
    hello, all new here. have an 02 wrx 2.0 I believe the turbo is bad. here's what it is doing. smokes like crazy when you start it up (oil) goes away after a few. still boosts but engine is missing so feels sluggish until the r's come up to about 3000. took the cooler off today and throttle body was full of oil and so was cooler. now I only see two ways of getting oil into the cooler, turbo or vent tube comming off of engine block. Ohh one more thing boost gage is reading negative numbers. i just got this car and in this condition. If it is so that the turbo is bad what are some good choices. can I use a TD05-H supposed to be a big 16
    Quote Originally Posted by bkautoman View Post
    I agree, so check the PCV valve first. If the valve is stuck that might explain the oil.
    That's discouraging though. You can use a 16G as long as the fittings (orientation) are for a Subaru, but you'll need more fuel and a different map too.
    Oct 2008
    just to let you know what i found to be the problem was too much boost. blew the side of one of the pistons out. waiting on parts to repair
