If it's not rhythmic, I wonder if you're describing wastegate flutter.
This is a discussion on Engine TICK within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an '07 completely stock Wrx Limited. SOME of the time while accelerating with a casual driving style there ...
I have an '07 completely stock Wrx Limited. SOME of the time while accelerating with a casual driving style there is an engine tick that is sooooo annoying. Much more noticable if driving next to objects or in tunnels. To narrow it down it really sounds turbo related because if I watch my boost gauge, only when there is minimal boost (throttle needed though) is there this mysterious noise. Under full throttle the noise seems to speed up enough to not sound out of the ordinary. At first I was thinking exhaust leak but I can't seem to reproduce the noise rev'ing in Neutral. (not enough boost in Neutral) Appreciate any suggestions!
or your just hearing piston slap, normal in our cars.
How Fast Can You Afford To Go?
It might be the wastegate...I doubt it's piston because it would be on somewhat of a regular basis right? Some days, nothing. Other days all day during mild acceleration I hear it. Pretty annoying. (if it is the wastegate any way to silence it?)
Does it go away 90% when you are in boost = normal
Paul
2007 MS3
Maintenance schedule and poke in the eyes:
http://www.clubwrx.net/forums/genera...nce-guide.html
When under full boost/throttle it goes away. If I'm on a back road just cruising along in 3rd gear let's say. If I give it some throttle even more a few moments, it makes the noise. The moment I let off it stops. If i really give it to it the noise is gone as well. Only seems to be under low boost.
Defiantly Waste Gate Flutter.
To make it quieter you can add some Dynomat (or equivalent) to the passenger side foot well.
Yea as long as it is normal that's fine...Just thought it was weird that it's not all the time even in duplicate driving scenarios.
