Reversed Polarity Battery: Now What!?
Results 1 to 6 of 6
This is a discussion on Reversed Polarity Battery: Now What!? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 05 Wrx stock block, vf39, pink inj, Story>>So, my battery died and i got one of my friends to come ...
    Registered User 914Wrx's Avatar
    Oct 2008
    Question Reversed Polarity Battery: Now What!?
    Story>>So, my battery died and i got one of my friends to come help me jump it.
    We get there and i connect the cables to my car and tell my friend to do the same(knowing my friend not to be car savy I remind him to make sure red to red and black to black). !Bang! crazy sparks come off his bat and i already knew. Its my falut im an ass for letting some one dumb touch my car.
    Problem>> I got a new batt and put it on seached the fuses and i blew the 80 amp main fuse. located bottem right of fuse box under the hood. Dont have the fuse yet, I want to know if i fried my ecu and/or utec piggy back.
    And if i should even try turning my car on. I have injectors and i run a map selecter with a large diffrence in maps. Has anyone else done this?
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Hopefully your fuses did their job and everything was protected. Hate to say it, but you won't know until you try to fire it up.
    Replace the fuses, get a new battery in, and turn it to the ACC position to see what happens. If everything looks and sounds normal, turn it over and find out.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Oct 2008
    Nobody has ever done this, really.
    Apparently not; nor does it make a difference. Really, if you don't try you won't know whether your ECU is fried or whether your car will fire up. The silver lining in the clouds though is that you are unlikely to now damage something that you've not damaged already. Check the fuses one last time, and go for it.
    Jul 2004
    Seattle, WA
    Quote Originally Posted by 914Wrx View Post
    I have , it's not a problem.
    The Fuse did what it was made to do, it broke the connection when it had an overload.
    It's an expensive mistake only because the fuse is like $8-10.
    Oct 2008
    Its alive. I blew the main 80 amp fuse. everything else was good did a full check.
