Results 1 to 4 of 4
This is a discussion on cel & cruise control problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i just removed my intake silencer, and i unplugged the maf sensor to take the airbox off. Everything is now ...
    Registered User Black X Dahlia's Avatar
    Apr 2008
    baton rouge, la
    i just removed my intake silencer, and i unplugged the maf sensor to take the airbox off. Everything is now back together and maf sensor plugged in, but im throwing a CEL plus my cruise control light is blinking.........im really confused. Anyone?
    How Fast Can You Afford To Go?
    Apr 2008
    baton rouge, la
    well after messing around a little bit i learned a few things. I think the ECU turns off your cruise control when you throw some CEL's as some sort of protocol to prevent damage. I ALSO just remembered my a/p shows engine codes, and it read Mass Airflow Low output & also another code reading Intake high output. Guessing it just had to reset due to unplugging the MAF sensor.
    Oct 2005
    Late Devonian
    Quote Originally Posted by Black X Dahlia View Post
    You may have gotten some crap on the MAF or the contacts need to be cleaned on the plug. Are all the hose clamps tight between the MAF and the turbo?
    Apr 2008
    baton rouge, la
    yea I made sure all the hoses were clamped tight. The cel and cruise control is gone now. I just drove around till it reset itself, I've seen this happen when unplugging the maf b4
