Noise from the rear
Results 1 to 12 of 12
This is a discussion on Noise from the rear within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a 02 wrx and whenever i make sharp right & left hand turns there is a rubbing sound ...
    Apr 2008
    Albany
    Noise from the rear
    i have a 02 wrx and whenever i make sharp right & left hand turns there is a rubbing sound coming from the rear but when i turn slight you cant hear it but the harder you turn the louder the rubbing sound if anyone has any ideas let me know i gonna change the diff fluid after that im all out of ideas ps it just hit 50kmi on the clock so thats about the age and usage of he car
    2002 PSM WRX 5mt Hella Slammed/Turboswapped/DomTuned/Daily RIG
    DUB
    DUB is offline
    Registered User DUB's Avatar
    Jul 2007
    SLT, CA
    Do you have wider than stock tires? Could be tire rub.
    Oct 2005
    Ocean Grove, NJ
    Apr 2008
    Albany
    i have the factory 16x6.5 with 205s
    Jul 2004
    Seattle, WA
    Best way to find out, is to jack up your car, get underneath it and start looking for fresh rubbing.
    DUB
    DUB is offline
    Jul 2007
    SLT, CA
    Quote Originally Posted by spoolordie View Post
    strike one for me.
    Apr 2008
    Albany
    if it were a wheel bearing how would i know which to replace or just do both
    Jul 2004
    Seattle, WA
    If it's happening when going around right and left turns, and the bearings are the problem, then it's best to do both sides.
    On my Mom's Geo Metro, it would stop making noise when the car was taken hard around right turn, so only the Right two needed to be done. But we did the left one's anyway.
    Apr 2008
    Albany
    so most likely the diff is outta the question
    Registered User pfsquirrel's Avatar
    May 2008
    NJ
    Wouldn't a bad bearing make noise going straight as well though?
    Are you sure it isn't low fluid in the rear diff? I'd get under there on a level surface and check that. It also *could* be seriously worn brake pads with the warning tabs digging into your rotors, which if going around a corner, sometimes will only make noise when the wheel tilts.
    I actually had an issue with a loose and worn rear strut that wiggled just enough that it sounded like I had a grinding sound.
    Best to check the small things first before blowing a **** ton of money accidentally.
    Jul 2004
    Seattle, WA
    Quote Originally Posted by pfsquirrel View Post
    Your right, wheel bearings make noise all the time.
    Registered User DstrbdTech's Avatar
    Aug 2008
    Have you checked the Bushings? What kind of rubbing sound is it....Is it a metal on metal rubbing or a plastic on metal or rubber on metal.
