oil plug gasket
Results 1 to 9 of 9
This is a discussion on oil plug gasket within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; or whatever you want to call it. the washer on the drain plug. how often do you have to change ...
    Jul 2008
    oil plug gasket
    or whatever you want to call it. the washer on the drain plug. how often do you have to change them? this is the 3rd time I have changed the oil but this time it is leaking. not bad but little drips. never did that before. I dont want to tighten it more cuz I dont want to strip the threads.
    2002 wagon stock auto
    By the book, every time you change the oil. In reality you can re-use them for a long while provided they are not over-torqued.
    You can use your thumb to keep most of the oil in the sump as you have a friend wipe off the drain plug, switch crush washers, and hand it back to you. You can do all this solo too if you're quick and good at planning ahead.
    Jul 2008
    what if I dont have friends or thumbs?
    That's a tough question. I certainly don't have any friends, but I do have thumbs so I've not run into too many problems the couple times I've had to replace drain plugs but keep as much oil as possible. If worse comes to worse change the oil again I suppose.
    Registered User WRXwagonMAFIA's Avatar
    Aug 2008
    some old backroad
    go to the local oil change and buy a hanful. i work at valvoline instant change and we change every oil change, i have yet to see a return customer leak oil
    04' WRB wagon stage 2
    wagon Mafia #1 Where my wagons at?
    Jul 2008
    thats sad about the friends. I was joking.
    ill just let it drip. I got a pan under it. ill be changing it again in a month anyway. I know check levels often.
    Registered User vttk_mig69's Avatar
    Jan 2008
    Sheboygan, WI
    i just went to the dealership today to get my filter and oil plug seal. its a cheap little ring, i change my own oil so i really dont care its like $0.50 its just worth getting a new one each time u change oil. i mean u realy want all that new fresh oil drippin out.
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Buy your filters from a dealer. They're almost the same price as an autoparts store and each one comes with the crush ring taped to the box.
    By the book your supposed to change the ring each oil change.
    Drip-pan under the car?!? That's just wrong on some level...
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Jan 2008
    Sheboygan, WI
    i say ohh well if it keeps my car from leaking oil il do it.
    P.S. just got done changing oil and rear diff oil. (my baby is good for another 3k.)
