Help with engine problem
Results 1 to 2 of 2
This is a discussion on Help with engine problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Gidday I have attempted to change my turbo, with a secongd hand turbo. After the change when I started my ...
    May 2007
    Gidday I have attempted to change my turbo, with a secongd hand turbo. After the change when I started my EJ20T wrx, it was smoking with white smoke a little. I took it for a drive not too hard, and when I got back it was smoking a little more. Straight away I thought, turbo is no good. I changed back to my old turbo but now I have the same problem. I took it for another drive, and it started to backfire. Got back home and there still is white smoke coming out of the exhaust and it smells heaps like petrol. I have a air fuel gauge and it was reading very very lean.
    Can somebody help me and tell me what I can try or what these signs mean?
    If you need more info about it just ask and I'll try giv u as much as I can.
    Thanks guys.
    Registered User Black X Dahlia's Avatar
    Apr 2008
    baton rouge, la
    First off the turbo most definitely isn't the problem at hand.
    Second, white smoke usually means ring job.
    Third, im going to need a list of your mods before i can take a crack at what could be causing you to run lean.
    How Fast Can You Afford To Go?
