I've been doing quite a bit of research on a/c problems lately and found out that a common problem on the '02 is the expansion valve going bad (happened on mine and I believe also caused a leak in my evaporator). This can cause your pressures to get wacky, which will cause the compressor to behave funny and the belt slipping/loss of power issue to occur. So before you assume it's a bad compressor, I would check your high and low pressures (this thread is a good start ) and make sure your exp valve is operating correctly.
LinkBack URL
About LinkBacks
] thanks for the heads up. I'll try that before the expansion valve. Is it true that the valve is under the dash and involves a lot of labor to get at it ?
