My New Wrx Problem
Results 1 to 11 of 11
This is a discussion on My New Wrx Problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am from Bulgaria and i bought 01 WRX with small accident. But the big problem is the engine. it ...
    Sep 2008
    Red face My New Wrx Problem
    it has check engine, it revs very slow and when i try to drive it, revs stops after 4500, i dont hear the turbo at all.
    what cable do i need to connect the cars ecu.
    Jul 2004
    Seattle, WA
    Hello, welcome to ClubWRX.
    To check the codes you need an ODB-II scanner, it connects to a port under the dash, on the driver side.
    Sep 2008
    OBD2 ELM327 USB CAN-BUS tool Interface Scanner
    is it gone work with ecuexplorer
    Jul 2004
    Seattle, WA
    Yes, that will work.
    Sep 2008
    1000 thanks to jeremy96gase
    and if somebody has a guess about the solution of the problem lets write
    Jul 2004
    Seattle, WA
    Please post the check engine code
    We can help find out what the problem is.
    I'm not sure how it works in Bulgaria, but in the USA some auto parts stores have ECU scanners, and will scan the ECU for free.
    Sep 2008
    Quote Originally Posted by jeremy96gase View Post
    We are 20 years behind you
    Aug 2008
    Panama, Central America
    similar problem I have with my evo one time, well, rev verry slowly and bug up the 4.5k rpm, the problem: some lose vaccum hose going to the BOV or wastegate, I don´t remember clearly...hope it helps
    Sep 2008
    i am looking for a fender with blinker and inner fender (plastic) on driverside. Can somebody help me.
    Sorry for my English
    Sep 2008
    I order Tactrix OpenPort 2.0 but now i see that it doesnt work with EcuExplorer.
    Which software have option "reset ecu" and work with Tactrix OpenPort 2.0?
    Registered User atrizzzie's Avatar
    Sep 2008
    Seekonk, Massachusetts
    it sounds like a possibly clogged cat converter. my bros old s10 wouldnt rev over 3k and the cat was junk
    edit. the cat was broken into pieces inside clogging the flow of exhaust gasses
