timing belt question
Results 1 to 5 of 5
This is a discussion on timing belt question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; At what milage should I change the belt on my 05 WRX? What other part should I change while doing ...
    Mar 2007
    PA
    At what milage should I change the belt on my 05 WRX? What other part should I change while doing it i.e. water pump, tentioner? Thanks.
    On the 2002 cars the belt is required at 105,000 mi. Check your own owner's manual though to make sure the interval has not been changed.
    The tensioners and water pump are popular items to replace whether they need it or not since everything's apart anyway. You may as well do the external belts as well, they come off first, and the coolant if you didn't do it at 90K.
    Les jeux sont faits.
    Aug 2008
    Kennett Square, Pennsylvania
    also any seals that may be leaking...i.e...crank,cam or i have even seen people do them as maintaince items also..again "while your in there"
  5. #4
    Quote Originally Posted by EvoEatr
    +1
    cam seals
    crank seals
    idler pulleys
    accessory belts
    oil pump o-ring
    hydraulic tensioner
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  6. #5
    Mar 2007
    PA
    Thanks all.
