soaking floor
Results 1 to 9 of 9
This is a discussion on soaking floor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi all i have just purchased a 98 scooby turbo and the passenger floor carpet is soaked ive had the ...
    Sep 2008
    midway
    Question soaking floor
    hi all i have just purchased a 98 scooby turbo and the passenger floor carpet is soaked ive had the carpet up but cant see no damage to the floor or any wholes can anyone help me please!!!!!!!!!!!!!!
    Registered User DstrbdTech's Avatar
    Aug 2008
    Theres several things to check...
    You're heater core could be gone which the year sounds about right that it would go out this time....
    If your antenna is on the right I have heard of those leaking over time.
    So check your coolant level if its still decent then I dunno what else to tell you. As I don't know subie motors but the symptoms you provide are a common thing on any vehicle that the heater core goes out on.
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    Do you have a down pipe installed and/or has the heat shield been removed?
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
    Sep 2008
    midway
    Quote Originally Posted by DstrbdTech View Post
    thankyou very much i will check these tommorow and see what turns up thanks again
    I guess I'll take that as a "no".
    -The J 𒂼𒄄
    Sep 2008
    midway
    Quote Originally Posted by TheJ View Post
    hi there the heat shield still seems to be in plaice and the down pipe seems standard im baffeld?
    There can be an issue where the lines that go through the fire wall of the passenger side, can over time become damaged by the increased heat off of after market down pipes and/or where the OEM heat shield has been removed. Especially if the lines have been moved and not secured properly. There was a recent thread on this issue. I searched quickly but was unable to find it, right this second.
    I would definitely check any areas where lines pass through the fire wall on the passenger side. I would also check the windshield seals.
    -The J 𒂼𒄄
    -The J 𒂼𒄄
    Aug 2008
    Kennett Square, Pennsylvania
    check the EVAP water drain hose and make sure it isnt clogged also not that likely but check the drain holes in the pinch welds...make sure they are opened up all the way....
