wrx doesnt accelerate smoothly - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on wrx doesnt accelerate smoothly within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by thevlad Yeah, it does sound more like running over a soda can. I guess I have to ...
    Oct 2005
    Late Devonian
    Quote Originally Posted by thevlad View Post
    Yeah, it does sound more like running over a soda can. I guess I have to flash to stage one then. Will a performance shop know what I'm talking about if I tell them to flash to stage 1?
    Your not getting wastegate flutter because you are accelerating hard over 5k rpms (wastegate is open). Wastegate flutter occurs when your wastegate is opening & closing - intermediate throttle at lower RPMs.
    Detonation is a big deal on turbo cars, don't let it keep happening or you will be shopping for another motor in short order. Detonation is a primary reason why pistons blow (they melt), and your car has already done that once. Just replacing the block does not treat the cause.
    Sep 2008
    So I guess i'm screwed. So replacing the whole engine is the only way to really fix the problem?
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    That's not really we he is saying. What he said was:
    1) It's not waste gate flutter because you said it happens over 5k rpm.
    2) If it is detonation you are having and you don't fix it' ... you will likely end up replacing your engine.
    At this point you may want to consider taking it to a professional to looked at it. Preferably somebody that tunes/works on Subarus
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
  6. #19
    Oct 2005
    Late Devonian
    Start with the basics -
    Log the car (get ecuexplorer from romraider.com & a compatible cable).
    Inspect & clean MAF (also remove &replace any non-stock intake)
    Make sure you have no air leaks in the intake tract before the turbo.
    Remove the intercooler and see if there is a bunch of oil pouring out (a few drips is ok).
    Injector cleaner, maybe seafoam.
    Pull the plugs - check for fouling and look for little beads of metal stuck to the electrode with a magnifying glass (deposits from your piston material if it is melting).
    Consider getting a protune.
    Edit: also check the fuel filter
  7. #20
    Sep 2008
    i put in a bottle of octane booster in the gas and the spark/crackle noise stopped but the acceleration is still not smooth. I'm still gonna to get it checked out though.
  8. #21
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    Probably not. Unless they are proficient in Subaru tuning.
    Good idea. It doesn't sound like good things are going on in there.
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
  9. #22
    Oct 2005
    Late Devonian
    I think your car may have a leftover tune for some previous mods that were removed for the sale. You may just need to flash an OTS stage I map and you can do this yourself (Cobb AP or Romraider). A reputable protuner could probably sort it out for you. If you post what area you are in someone may be able to recommend one.
    Good Luck.
  10. #23
    Sep 2008
    just needed a tune
