ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > General Maintenance, Troubleshooting & Accidents.
General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here!
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 08-30-2008, 07:53 AM   #16 (permalink)
Evil_Panda's Avatar
didn't post it three time for no reason buddy it was my comp thank you very much wouldn't send it but it did....anyway thanx for the info and fft i let the car set over night an i went out this morning CEL turned on heard it prime and it started but to answer your question previously i could not here it prime
Quote:
Originally Posted by Donkey View Post
Impreza Manuals | ken-gilbert.com
/\ Repair manuals.Electrical problems are not gonna be easy to diagnose over the internet.My advice is to buy a multimeter (if you don't have one yet) and start checking sensors.Crank and oil pressure sender would be the ones to start with first.Then check the injectors and coil packs next to seee if they are getting voltage.You can get injector"noid lights" pretty cheap.They plug into the injector harness and will light up when that injector lead is being energized.Also when you turn the car to the "on" position can you hear the fuel pump prime?You should always hear the fuel pump prime for about 5-10seconds and shut off when you turn the car to "on".If not the relay might be sticking or going bad.The relay is located in the passenger kick pannel by the door hinge.It's green.
Also no need to triple post your problem.Your well on your way to irritating the modderators as well as everyone else.........
Evil_Panda is offline   Reply With Quote
Old 08-30-2008, 09:16 AM   #17 (permalink)
Evil_Panda's Avatar
ok here is where i stand at this time if anyone could give me sum more advice i took of the filter tryed to blow threw it it worked a littel bit but was still hard to then i tried to start the car to see if the fuel would come out the hose nothing came out and when i turned the key to the on position before i started it i never heard the fuel pump prime?? any ideas
Old 08-31-2008, 09:49 AM   #18 (permalink)
Evil_Panda's Avatar
Any ideas??
2002 WRX 82000mil
it cranks but wont start i dont here the fuel pump prime
is that the prob? or is it the starter soleinod?
thanx EPanda
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Very bad hesitation at high boost 02_silver_wagon General Maintenance, Troubleshooting & Accidents. 8 09-03-2009 04:08 AM
Uh oh.. bad bad smell from clucth after LAUNCH zigger Everyday Impreza Talk 14 06-10-2006 11:06 AM
Slight Exhaust Leak...Is It Really Killing Me That Bad??? LittleAP783 Engine Modifications 22 06-16-2005 08:59 PM
I got OWNED BAD! Butterfingers Comparison: WRX vs World 20 10-02-2003 08:09 PM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
