my fifth gear
Results 1 to 4 of 4
This is a discussion on my fifth gear within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok im kinda new here so sorry if i mess this up. but i got an 04 wrx with about ...
    Aug 2008
    my fifth gear
    but i got an 04 wrx with about 65k miles.
    When shifting from 4th to 5th at higher speeds my 5th gear grinds for like a split second and then drops in.
    when at lower speeds it drops in perfect with no grind.
    i was just wandering if i just change my transmision fluid that it will help the problem? or is it something more?
    Registered User ProdriveX's Avatar
    Jun 2008
    Wrx
    Im have the same problem with my tranny. Its your synchro's. You could change the fluid, but the will only cover it for awhile.
    Registered User spatwinturbo's Avatar
    Oct 2009
    Dallas, TX
    Quote Originally Posted by ProdriveX View Post
    Same problem here, i went with mobil fluid and did the same so i changed to castrol and is doin the same.
    Do you recomend a new clutch?
    Registered User Ashesofthewake's Avatar
    Oct 2009
    CNJ
    Quote Originally Posted by spatwinturbo View Post
    If it is the synchro that won't help. If you double clutch it shouldn't grind, but the only way to fix it would be a new synchro. I think.
