ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > General Maintenance, Troubleshooting & Accidents.
General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here!
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 08-26-2008, 03:49 PM   #1 (permalink)
wrx0131's Avatar
Turbo inlet pipe help
i popped my hood earlier today and found that a line coming out of my turbo inlet pipe was capped off by a screw....does anyone know where this line is connected to??
wrx0131 is online now   Reply With Quote
Old 08-26-2008, 07:38 PM   #2 (permalink)
wrx0131's Avatar
anybody??
Old 08-26-2008, 07:46 PM   #3 (permalink)
DUB
DUB's Avatar
Looks like line 4 to me.
Line 1 plumbs the compressor housing to one end of the T-fitting. This line contains the brass restrictor pill.
Line 2 plumbs the wastegate actuator to the opposite end of the T-fitting.
Line 3 plumbs the middle of the T-fitting to the wastegate solenoid valve.
Line 4 plumbs the other side of the wastegate solenoid valve to the turbo-inlet pipe.
From: CobbTuning.com - How Subaru’s Factory Boost Control System Works
__________________
"Blondes not bombs....brunettes not fighter jets"
Stg 2 Wagon
Bugeye Mafia #152
DUB is offline   Reply With Quote
Old 08-26-2008, 07:53 PM   #4 (permalink)
wrx0131's Avatar
yeah i was looking at that but i have a boost controller, not the stock boost control solenoid so i dont know where it would go......i dont know if my mechanic messed around with my lines and changed something
Old 08-26-2008, 08:12 PM   #5 (permalink)
DUB
DUB's Avatar
Quote:
The fact that you have an after market boost controller probably would have been relevant information to include in your original post.
In that case, I would guess that the boost controller you have doesn't need that line. But, I don't know anything about installing an after market boost controller, so......
Why don't you just ask your mechanic?
__________________
Stg 2 Wagon
Bugeye Mafia #152
Old 08-26-2008, 08:28 PM   #6 (permalink)
wrx0131's Avatar
lol i dont want to take my car to him for that stuff because i have alot of aftermarket parts and i dont want anyone messing with my car.....i took it to him to get a little sound checked out and it was fixed but in the process he removed a bunch of my stuff and then put it back on.....i already had to fix my radiator overflow hose by myself.....and now when my car is cold when it starts up and i give it gas when the rpm returns to idle it drops to like 400 rpms before returning to normal.....sounds like a leak or something......i had the same problem before and i took it to dynoflash in connecticut and they were able to fix it and now it happens again....thats why i dont like just any mechanic messing with my car.....i live in NY so its hard for me to take my car to connecticut because i need it for school and work
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
turbo inlet question 1bdrex Engine Modifications 7 08-16-2008 05:29 PM
turbo inlet hose collapsing rotarypower8 STi Technical Forum 10 10-16-2005 04:34 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
