To pass canadian inspections i need to install daytime runningn lights and all i need to complete this is a signal - any power source that is on when car is running but not on when just the key is on. the instructions say wrap around the spark plug wire but i think there should be an easier way. the wire is long enough to reach across the engine bay, the module is mounted next to the battery. the car is 2005 wrx. thanks
Some examples as per the shotty instructions : oil pressure switch or a high point 12v source when ignition is in run position
